Samsung Galaxy s6 edge - message "device is not busy with si
Geralt_z_Riv 2733 11
Why won’t my used Samsung Galaxy S6 Edge read any SIM card, why doesn’t Wi‑Fi turn on, and is there any chance to fix it?
The SIM/network problem is most likely either an operator IMEI block or a hardware fault on the main board, and if a reset doesn’t help, the phone may not be repairable by software alone [#16598914][#16598944][#16598303] Wi‑Fi is not caused by an IMEI block, so its failure points to a separate fault or software issue [#16599730] A hard/factory reset is the first thing to try, and if that fails, flash the latest firmware/software as a precaution [#16598112][#16599987] If the phone is blocked by the operator, the practical advice was to return it to the seller [#16598303]
  • #1 16598082
    Geralt_z_Riv
    I bought a used Samsung galaxy s6 edge which has the following problems:
    - Does not read any sim card, after inserting the card a message appears that the device is not networked,
    - Wi Fi does not work, tries to turn on but can't,
    - After pressing the lock button, the image on the screen only appears after 5 seconds.
    Is there a chance to solve these problems?
  • #2 16598112
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Where did you buy the phone, from whom was it damaged or functional?
    IMEI is displayed correctly?
    First, do a hard reset from the buttons.
  • #3 16598281
    Geralt_z_Riv
    I bought it on olx from a private person. It had been operational. IMEI is displayed.
  • #4 16598303
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    If the factory settings do not fix the problem, give it to the seller because you will not be able to repair it yourself, unless it is blocked by imei.
  • #5 16598558
    Geralt_z_Riv
    But is this a problem of damaged components on the motherboard or defective software?
    nutergsm
    Help: 1034
    Rate: 1665
    Phone blocked by the operator or damage to the plate.
    badboy84
    Help: 1197
    Rate: 1486
    Doesn't this phone come from Plus? I know that it was loud about it, maybe they still use such practices and block the phone by IMEI if someone is in arrears with payments.
  • #8 16599010
    Geralt_z_Riv
    I guess you're right ... I didn't think it might have been blocked by the operator. And the lack of wi fi could also be caused by this blockage?
  • #9 16599730
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Wifi has nothing to do with it. Have you done a reset? Did you play soft?
  • #10 16599960
    Geralt_z_Riv
    Reset I did nothing helped.
  • #11 16599987
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    So prophylactically upload the highest soft, but in my opinion the damage will be on the disc.
  • #12 16600579
    Geralt_z_Riv
    I understand thanks for your help
The discussion revolves around issues faced by a user of a used Samsung Galaxy S6 Edge, including inability to read SIM cards, non-functional Wi-Fi, and delayed screen response after pressing the lock button. Initial suggestions include performing a hard reset and checking the IMEI status. The user reveals the phone was purchased from a private seller and confirms the IMEI is displayed correctly. Responses indicate potential causes such as operator blocking or motherboard damage. The user is advised to consider software updates, but it is suggested that hardware issues may be the root cause of the problems.
