[Solved] Samsung S6 EDGE Touchscreen Issues: Unresponsive Home/Back Button, Ghost Touches, Fixes?
db17 5250 5
  • #1 17300202
    db17
    The problem in my Samsung appeared more than a month ago. Initially, the HOME / BACK button did not work. After a week, everything returned to normal. Two weeks ago the touch fell completely - no reaction in any place, you could not even turn off the phone so I had to wait for it to discharge. After these two weeks, I recharged the phone, lay for about 2 days unused and suddenly the touch began to work. The problem is that sometimes it hangs, that you can not do anything, however, after locking and unlocking the screen everything returns to normal: o Where should you look for the reason ? Is the display itself already finished, maybe some tape or the software itself? The phone has been in use for over two years.
    misiekelk
    Help: 47
    Rate: 121
    If you didn't fly it somewhere, a tape of touch lets you go. It's about connecting the touch tape with LCD tape. This is a tape-tape combination, "glued" with anisotropic tape. Unfortunately, to fix it you need to separate the lcd from the frame and play.
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    Initially restore the factory settings. If this does not help, substitute another fullset.
  • #4 17300744
    db17
    To be honest I just suspected a slight flooding ... (by the way a funny situation, but it happened just after visiting the gym, where the phone was attached to the body and my body was a bit sweaty ... :D ) @misiekelk how can it be affordable? To be honest I also bet on the battery - I noticed that it holds much less and may not provide adequate voltage to the display's power supply system (such a loose observation).
  • #5 17300750
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    If flooding, go to the nearest service center as soon as possible, if you care about your phone. No one will give you the prices here and every service has its own rates. The battery has nothing to do with it.
  • #6 17741744
    db17
    The phone returned to normal after 2 weeks :)
