Mercedes W202 C180 (1998) - Automatic Low Beam Module Installation & Relay Location
kielepl 21141 5
  • Asking for low-beam relay location and wiring advice
    #1 16518480
    kielepl
    Mercedes W202 C180 after lift 1998
    I plan to insert an automatic module for switching on the low beam after a 13.3V increase, from what I read in the manual you need to find the relay from the low beam and the position and plus after ignition, there is no problem with the plus, but the relays for China I do not see any advice?
    Plus a module diagram
    Regards
  • #2 16518863
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    In the polyphase, the dipped-beam headlights are switched on by semiconductors located in the SAM. There are no typical light relays.
  • #3 16518873
    kielepl
    ohhh, I would learn, that is, I think I will stick to the light switch normally, I hope I find the right cables
  • #4 16518890
    andrzej20001
    Help: 1578
    Rate: 6669
    You will not find. Activate the lights in the menu.
  • #5 16518901
    kielepl
    Andrzej, will you expand the topic?
    Added after 18 [hours] 44 [minutes]:
    welcome back
    I buried a little in the light switch, with a meter in my hand. and it came to me:
    over the weekend I will plug in with a brown cable at + 12V fixed and +12 after turning into positions, I will have to bridge them so I will lose left and right parking positions in the switch, then with the blue cable +12 fixed and +12 passing, plus after ignition I will probably take lighter and minus I will find quite easily (for sheet metal)
    I will take photos and insert a tube, it may be useful to someone.
