WD10EZRZ Blue 1TB vs Seagate Barracuda ST1000DM010: Choosing the Best 1TB Hard Disk Drive
MSIAEGIS-Ti3VR7RE 19287 8
  • #1 16519607
    MSIAEGIS-Ti3VR7RE
    Hi, I do not know which hard disk would be better WD WD10EZRZ Blue 1TB or maybe this SEAGATE BARRACUDA 1TB 3.5 "(ST1000DM010)?
  • #2 16519789
    guciq
    Help: 24
    Rate: 134
    It depends on what. Put yourself both on the net in the comparison engine.
  • #3 16520048
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8293
    Theoretically, Seagate should be better in terms of performance. WD is slow rotation - 5400RPM. WD10EZEX would be a better solution with WD Blue. Alternatively, you can also pay attention to the Toshiba P300.
  • #4 16520470
    Brozerihno
    Help: 28
    Rate: 44
    both are good disks but I think I would choose WD to have more confidence
  • #5 16523022
    roman106
    Help: 107
    Rate: 271
    Seagate is known for its defective series of drives in the past, so the choice seems easy. I met personally with such a defective disc, which is why I do not recommend this company.
  • Firmware defects are fixable; new drives fail across brands
    #6 16523272
    dt1
    Help: 7315
    Rate: 8293
    The defect you write about was a disadvantage of the firmware and it was possible to correct it. Such a failure does not cross out all the next products of the company. Each producer has something behind his ears. A good example for Seagate is the ST1000DM003 model, initially released as a 64MB cache model. As there was a moment on the market, the producer did not praise too much, he broke the series into two models - one from 32MB cache, the other from 64MB cache. Of course, not praising this too much, the designation of the model remained the same for both disks, only after P / N and reading the specifications could be found the difference.
    Otherwise, WD sells the Green series at the moment as Blue (previously, the Blue series had 7200 RPM, now they can suddenly have 5400 RPM). It is also not an interesting play, although at least the models differ and the parameters are not hidden.
    I met with many of the defective Seagate drives. I have also encountered many defective WD drives. Statistically, I buy "half and half", once WD, once Seagate, I send a disc with a complaint one time, once to another company, it's even hard to say whether it is more to one than another. In general, new disks in my opinion are definitely more emergency than older constructions.
    Recently, I also give Toshibom P300 a chance, even though the previous series (dt01ac100) did not impress me with their failure. But considering that Seagate or WD managed to get damaged after removing it from the foil (first scan, first inclusion, damaged sectors), I might as well change the Toshiba version.
  • #7 16554412
    gsm231
    Help: 11
    Rate: 40
    I assure you that WD drives are trouble-free and much more durable than seagate. I do not have a lot of confidence in segate, if you want a cheap drive then seagate like a good one, but more expensive it's a wider one. Privately, seagate will not buy.
  • #8 16556393
    Ronin64
    Help: 248
    Rate: 349
    @ gsm231 I have experiences opposite to yours. I prefer Seagate (I have never failed in this company) than WD. It turns out that it has dt1 and its "half in half" :)
  • #9 16556745
    Robert B
    Help: 2027
    Rate: 1412
    I definitely support :)
    For the newer Seagate series, I got offended after a few failures, although I had earlier, very successful series such as ST1000528AS. WD Blue are much slower than the Toshiba P300 and when it comes to me, I "changed" to P300 disks :)
The discussion revolves around the comparison between the WD10EZRZ Blue 1TB and the Seagate Barracuda ST1000DM010 hard disk drives. Users express varying opinions on performance and reliability. Some suggest that the Seagate model may offer better performance due to its higher RPM, while others prefer WD drives for their perceived durability and reliability. Concerns are raised about Seagate's past defective series, although some users defend the brand, citing personal positive experiences. Alternatives like the Toshiba P300 are also mentioned as viable options. Overall, the choice between the two brands appears to hinge on individual experiences and specific use cases.
