Better Drive for Longevity: WD Blue WD10EZEX vs Seagate ST1000DM010 & Crucial MX500 SSD
adamm1709 6267 15
Which 1TB secondary drive is more durable for everyday use: WD Blue WD10EZEX, Seagate ST1000DM010, or a Crucial MX500 SSD?
For everyday longevity, a good SSD like the Crucial MX500 is the safer choice overall, while among the two HDDs the WD10EZEX is preferred over the ST1000DM010 [#20391292] Current drives are said to fail more often than older ones, and for storage use the advice was to consider quieter/cooler 5400 RPM CMR models such as WD Purple or Red Plus instead of 7200 RPM desktop drives [#20391292] Another opinion was to avoid WD Blue, Green, and cheap Seagate models, with WD Red, Purple, or Black suggested instead, but with the warning that Red EFAX models are SMR and should be avoided [#20393676] [#20393688] It was also noted that the old WD10EZEX is still the “correct” Blue model, while newer Blue variants are better avoided; WD10EZRZ is CMR but only 5400 RPM [#20393688] [#20393786] Even so, backups are still necessary because SSDs can fail without much warning and data recovery is usually harder than with an HDD [#20391292]
  • SSD durability compared with WD Blue and Seagate HDDs
    #1 20390915
    adamm1709
    Help: 44
    Rate: 107
    Let me dig up the topic, because my Seagate ST1000DM003 drive after more than 9 years looks like it's raining and I want to buy a new similar 1TB.
    I'm thinking the same, i.e. Segate ST1000DM010 or WD Blue WD10EZEX with a speed of 7200, at least that's what x-kom shows.
    I reject the P300, I've heard of returns, some failures - it doesn't convince me.
    Have your opinions changed after more than 5 years? How do you rate the durability of these drives compared to their counterparts from 5, 10 years ago?
    I want to buy the disk as a second one next to the system SSD. I will use it everyday.
    I was thinking about SSD, but I have a system, I don't care about speed and price. But how do you think they compare to these HDDs when it comes to durability and failure rate? for example, the apple of my eye is the SSD Crucial MX500.
    If I had information that I can count on SSD more when it comes to life, less failure rate, I would think about it. By this I mean time to make a copy in case you notice something going on.
    Taken from the topic: Which drive is better WD or Seagate
    by dt1 on 18 Jan 2023 02:41
  • SSD longevity depends on model and usage
    #2 20391289
    freebsd
    Help: 766
    Rate: 2033
    adamm1709 wrote:
    How do you rate the longevity of these drives to their counterparts from 5, 10 years ago?
    No such reference is possible. Too many variables.
    adamm1709 wrote:
    If I had information that I could count on an SSD more in terms of longevity, less failure rate then I would consider it.
    I have yet to have a Samsung SSD fail. It's just that I only use the top models. Perspective probably already ~10 years.
    Personally I would buy an SSD, but from an established company. Even of the cheap ones, as I did recently: https://youtu.be/A60yWi1Hyfs
    However, WD drives, not the top ones, I've only been using for ~3 years.
    SSD offers lower failure risk than HDD
    #3 20391292
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8291
    adamm1709 wrote:
    I'm thinking of the same thing i.e. Segate ST1000DM010 or WD Blue WD10EZEX with 7200 speed, at least that's what x-kom shows.
    P300 I reject, I heard about returns, some failures - does not convince me.
    Welcome.
    ST1000DM010 and WD10EZEX are also failures, and I'd collect a carton of those models too, if I did a good search in the basement. Although I will admit that I have a lot less Seagate in my scrap cartons, but not because they are better, just because after the ST1000DM003 I stopped buying drives of that brand due to the failure rate, which in my subjective feeling started to increase a lot in the newer models.
    Of the two, I would recommend the WD10EZEX, also failures happen, but alas - they are only mechanical drives.
    adamm1709 wrote:
    Have your opinions perhaps changed after more than 5 years? How do you rate the durability of these drives to their counterparts from 5, 10 years ago?
    I want to buy the drive as a second one next to the system SSD. I will be using it daily.
    The current drives seem to have more failure rates than the older ones. When it comes to storage drives I often buy 5k RPM instead of 7k RPM (they are usually a bit quieter and a bit cooler). That is, for WD Purple or Red Plus (WDxxPURZ, WDxxEFPX).
    adamm1709 wrote:
    I was thinking about an SSD, but I have one for the system, I don't care so much about speed and the price. But how do you think, how do they compare to the HDD when it comes to longevity, failure rate? for example, my eye catcher is SSD Crucial MX500.
    SSD prices have come down recently, so another MX500 1TB is worth considering. An SSD only has two disadvantages - it's a bit more expensive and when it breaks down, it's often impossible to recover any data at home. And although I like the MX500 a lot I wouldn't give it unlimited trust either. With a CMR HDD, if something goes wrong and you make a few bad sectors, you can still recover something yourself (eventual data recovery is simpler and cheaper). So if speed is not a priority, HDD may have some upside.
    adamm1709 wrote:
    If I had information that I could count on SSD more in terms of longevity, less failure rate then I would consider. By this I mean the time to make a copy in case I notice something going wrong.
    My impression is that a good SSD will fail less often than a standard HDD, however backups are rather necessary before a failure, as very often an SSD will no longer give you time to escape with your data in the event of a failure.
  • #4 20393640
    bolekis
    Help: 200
    Rate: 264
    If the motherboard and housing allows it, I suggest 2xHDD RAID1. If the budget is a problem, you can even buy used, better from different manufacturers but with similar parameters (SATA, RPM, cache) and with an acceptable SMART status.
    I currently have Seagate ST1000DM003-1ER162 - it still works, the second one fell and was replaced with Toshiba HDWD110.
  • #5 20393676
    qs300
    Help: 242
    Rate: 362
    If you care about the life of the drive, give a wide berth to WD Blue, Green and cheap Seagate. With WD, I recommend Red, Purple, Black, they are more expensive, but more reliable and less emergency.
  • #6 20393688
    dt1
    Help: 7315
    Rate: 8291
    Not every WD RED is worth buying. For example, the RED models of the EFAX series should be avoided, they are SMR models (except for two capacities).
    And not every blue should be avoided. Old model WD10EZEX, still available, it was still the correct model. The newer ones are actually better to avoid.
  • #7 20393740
    adamm1709
    Help: 44
    Rate: 107
    which newer? I haven't seen a newer blue.
    The Black series is interesting, supposedly better than Blue, but more than twice as expensive
  • #8 20393786
    dt1
    Help: 7315
    Rate: 8291
    WD10EZRZ - CMR, but 5400 RPM (basically a rebranded old GREEN series).
  • Recommends Seagate 2TB and WD Blue or Black drives
    #9 20395190
    MSIAEGIS-Ti3VR7RE
    Hello, you wrote which drive is better WD or Seagate I will answer you this question yes it depends on what because if you count on speed and capacity or lifespan I recommend Seagate 2TB 7200RPM for the second product it is WD I recommend Blue series drives that have less wear heads, use less energy if that's what you care about, and are ideal for desktop computers. On the other hand, I can also recommend you the WD Black series this series is for the user who cares about creating the best system performance and perfect gaming experience these are great drives because I currently have just such a model and I have been using it for a very long time it is 2TB 3.5' 7200RPM 64MB cache. What's more, I can recommend you, I'm sure that my opinion will be useful to you and is exhaustive in the subject of HDD drives.
    Regards, Aleksander sovereign of the Second Republic of Poland
  • Need for exact drive models and test data
    #10 20395232
    dt1
    Help: 7315
    Rate: 8291
    MSIAEGIS-Ti3VR7RE wrote:
    if you count on speed and capacity or lifespan, I recommend seagate 2tb 7200rpm
    What specific model does your colleague have in mind?
    Because such an opinion without specifying the model makes no sense, considering that Seagate offers several 2TB / 7200 models, and adding even older series that can be found somewhere there, it does a lot.
    WD recommend the Blue series drives which have less wear heads, consume less power if you care about it and are ideal for desktop computers
    Sounds a bit like marketing babble. The model is missing again, and the blue series can be a 5400 disk, 7200 disk, cmr disk, smr disk. As for the revelations about the wear of the heads, even the manufacturer's marketing team defeated my colleague and I guess that my colleague will not be able to cite any reliable data on this subject. As for the amount of electricity, it's hard to say, because it is not known which model blue has. A colleague has thoughts.
    I can also recommend you the WD Black series this series is for the user who cares about creating the best system performance and perfect gaming experience these are great drives because I currently have just such a model and I have been using it for a very long time it is 2tb 3.5' 7200rpm 64mb cache
    Again, no model, and there are several. The mythical black models may amaze with their performance, but not as advertised. As it turns out in tests, this efficiency does not differ much from the structurally comparable blue series with similar parameters (i.e. cmr, 7200).
    The review is far from exhaustive. Not a single model of the drive is given, and there are also a lot of statements that are not reflected in any reliable tests. This is a more subjective evaluation of several drive families, but without any details whatsoever.
  • 2TB 7200rpm drive recommended for speed and capacity
    #11 20396611
    adamm1709
    Help: 44
    Rate: 107
    depends on what because if you count on speed and capacity or life, I recommend seagate 2tb 7200rpm
    I don't think these 3 parameters go hand in hand ?
    it seems to me that the 5200 will live longer from a logical approach. On the other hand, 2TB is often two platters inside, which is, as I understand it, a greater chance of failure than one platter, and the 1TB version often has one.
    Only the 5-year warranty is conspicuous. But I wonder what the lifespan looks like in reality compared to blue, is there any point in paying more than twice as much.
  • Blue and black drives appear nearly identical internally
    #12 20396633
    dt1
    Help: 7315
    Rate: 8291
    I can't find this material now, but once on a forum with Cyrillic I found a post where a guest compared blue and black models with similar parameters (same capacity, same cache, more or less similar year).
    He compared the weight, the difference was 1 gram (which at 600-700g is within the measurement error).
    He compared the sound of the launch (tones and clicks of the warhead assembly at launch - something like an acoustic signature) - they came out very close to him
    He compared the speeds in the benchmark - the averaged results of several measurements were very close.
    He compared the electronics, disassembled both and compared the interior.
    Then he came to the conclusion that they differed most in the color of the sticker and the length of the warranty. Although who knows, maybe there are some subtle differences in the software, but as he said, in the tests it was not too noticeable.
    The older black series seem to be more different.
  • #13 20396699
    artaa
    Help: 1818
    Rate: 1699
    Black was always bought mainly for the guarantee, once (teen years ago) the surcharge was not great, so it was worth it.
  • Recommend choosing drives by exact model numbers
    #14 20399651
    MSIAEGIS-Ti3VR7RE
    I see that my opinion was not useful, so please look for disks by models, such as Barracuda ST2000DM008. As for the statement 'adamm1709', before you say that these 3 options do not go hand in hand, he will prove this thesis? Then colleague 'dt1', even though there are a dozen or so models of these drives, the one who is looking for the best one should look at the drive page, this is: https://www.seagate.com/pl/pl/ or https://www.westerndigital.com/ pl-pl/brand/wd and find the best one.
  • #15 20399685
    dt1
    Help: 7315
    Rate: 8291
    Just ST2000DM008 is rather an example of a model that is not worth buying, it is an SMR drive and only for this reason it is better to look for another model
    I see that my opinion was not helpful
    The opinion was not useful because it did not contain disk models.
  • #16 20399779
    MSIAEGIS-Ti3VR7RE
    I agree because I did not specify specific models. I can only say that I know a lot of disk models that I have had a lot of experience with them.
The discussion revolves around the durability and reliability of various hard drives and SSDs, specifically comparing the WD Blue WD10EZEX, Seagate ST1000DM010, and Crucial MX500 SSD. Users express concerns about the longevity of HDDs, particularly after experiencing failures with older models. Recommendations suggest avoiding lower-tier WD and Seagate drives, favoring higher-end models like WD Black and Red for better reliability. The conversation also touches on the differences between HDDs and SSDs in terms of failure rates and lifespan, with SSDs generally perceived as more reliable. Specific model recommendations include avoiding SMR drives like the Seagate ST2000DM008 and considering RAID configurations for added data security.
TL;DR: Over ~10 years of top‑tier SSD use, "I have yet to have a Samsung SSD fail." For longevity, pick an SSD from an established brand; even affordable models can be fine. [Elektroda, freebsd, post #20391289]
Why it matters: This FAQ helps PC upgraders choosing a 1TB secondary drive (WD Blue WD10EZEX vs Seagate ST1000DM010 vs SSD like MX500) prioritize longevity, failure risk, and backup strategy.
Which is better for longevity: WD Blue WD10EZEX or Seagate ST1000DM010?
Both can fail. Of the two, choose the WD Blue WD10EZEX. The expert stopped buying newer Seagate models after ST1000DM003 due to elevated failures in his experience. Regardless, they are mechanical HDDs, so keep reliable backups. [Elektroda, dt1, post #20391292]
Are today’s HDDs less durable than drives from 5–10 years ago?
They seem to fail more often. For storage roles, prefer 5k‑RPM models because they run cooler and quieter than 7k‑RPM. That choice can reduce thermal stress in everyday use. [Elektroda, dt1, post #20391292]
Is a Crucial MX500 1TB safer long‑term than a 1TB HDD?
MX500 1TB is worth considering. "A good SSD will fail less often than a standard HDD." However, consumer SSD failures often prevent home data recovery, so back up proactively. [Elektroda, dt1, post #20391292]
Do SSDs fail without warning, leaving no time to copy data?
Yes. In many cases, an SSD gives no practical warning at failure. As the expert wrote, "very often an SSD will no longer give you time to escape with your data." Backups must exist before failure. [Elektroda, dt1, post #20391292]
Which WD Blue models should I actually buy for reliability?
Pick the older WD10EZEX, which the expert calls a correct model. He advises avoiding newer Blue variants. Always verify exact model numbers before purchasing. [Elektroda, dt1, post #20393688]
Should I avoid WD Red EFAX models?
Yes. WD Red EFAX models are SMR (except two capacities) and should be avoided. Look instead at non‑SMR alternatives in the Red Plus line. [Elektroda, dt1, post #20393688]
Is Seagate ST2000DM008 an SMR drive I should skip?
Yes. The ST2000DM008 is SMR and the expert recommends choosing another model for general workloads. [Elektroda, dt1, post #20399685]
5400–5900 RPM vs 7200 RPM: which is better for cool, quiet storage?
For storage, 5k‑RPM drives are preferable. They are usually a bit quieter and cooler than 7k‑RPM drives. That makes them sensible for bulk, everyday use. [Elektroda, dt1, post #20391292]
Are WD Black drives truly faster than Blue, or is it mostly warranty?
In comparable generations, performance differences can be small. One teardown and testing comparison found "they differed most in the color of the sticker and the length of the warranty." Older Black models were more distinct. [Elektroda, dt1, post #20396633]
Is setting up 2x HDD RAID1 a good move for longevity?
Yes, if your motherboard and case allow it. You can even mix manufacturers with similar SATA, RPM, and cache specs, provided SMART status is acceptable. RAID1 improves availability, but still keep backups. [Elektroda, bolekis, post #20393640]
Can I fairly compare longevity across brands or years?
Not reliably. "No such reference is possible. Too many variables." Usage, workload, environment, and specific models all matter. Prioritize backups over brand folklore. [Elektroda, freebsd, post #20391289]
How should I prep a used or new HDD before trusting it?
  1. Check SMART and accept only an "acceptable SMART status."
  2. Match SATA, RPM, and cache if pairing drives; mixing brands is fine.
  3. If supported, configure RAID1 for resilience. [Elektroda, bolekis, post #20393640]
Have experts here seen SSDs last a decade in practice?
Yes. One expert reports ~10 years using top Samsung SSDs with zero failures: "I have yet to have a Samsung SSD fail." He still advises buying from established brands. [Elektroda, freebsd, post #20391289]
If speed isn’t a priority, does an HDD still have an upside?
Yes. With a CMR HDD, limited bad sectors may still allow partial self‑recovery. SSD failures often block home recovery entirely. Back up regardless. [Elektroda, dt1, post #20391292]
