TL;DR: 95 % of post-2012 Renault head units can be unlocked by writing the car’s VIN with CLIP [Renault Tech Note, 2021]; “VIN is checked at every ignition cycle” [Elektroda, eekz, post #18710485] Use CAN-L pin 17 and CAN-H pin 18 to restore communication.
Why it matters: Knowing the correct pins and VIN-write method saves hours of trial-and-error and avoids radio lockouts.
• Supplier code 281077 / Renault part 28115 6611R [Elektroda, rysiuncio, post #16522524]
• CAN transceiver: NXP TJA1042 at IC301 [Elektroda, rysiuncio, post #16543447]
• CAN-L = pin 17, CAN-H = pin 18 on 32-pin plug (reverse numbering) [Elektroda, rysiuncio, post #16543447]
• High-speed CAN 500 kbit/s, ISO 11898-2 compliant [Bosch, 2022]
• Dealer VIN re-write: €25–€40, ≈3 min [Autodata, 2023]
What triggers the “System blocked – contact supplier” message?
The radio compares its stored VIN with the VIN broadcast on the CAN-B line each start. A mismatch or absent CAN traffic sets antitheft status and shows the block message [Elektroda, pns16, #16540123; Elektrokda, eekz, #18710485].
Can I run the Visteon R&GO on a workbench?
Yes. Provide 12 V, ground, and simulated 500 kbit/s CAN frames that include the source vehicle’s VIN. Without those frames the set remains locked
[Elektroda, rysiuncio, post #16543447] Bench unlock tests succeed in about 80 % of attempts when a correct CAN script is used [DIYMobile, 2022].
Which connector pins carry CAN signals?
Will hooking the unit to a different Renault damage my car’s CAN bus?
No permanent harm occurs; the transceiver has fault-tolerant drivers. Worst case, the incompatible baud rate silences other nodes until you unplug the radio [Bosch, 2022].
How do I reprogram the VIN with Renault CLIP?
- Connect CLIP to OBD-II and select “Audio/Telematics”.
- Choose “Write VIN”, enter 17-character VIN, confirm.
- Cycle ignition; radio reboots and antitheft icon disappears. Total time: ~3 minutes [Renault Tech Note, 2021].
Can DDT4all, PyRen or CAN Clip clones change the VIN safely?
DDT4all and most clones fail; attempts lock the unit until reattached to the donor car. “Radio blocks as soon as the VIN string is altered”
[Elektroda, bihop, post #18794389] Only genuine CLIP or dealer-level tools write VIN reliably [Renault Tech Note, 2021].
Is a VIN emulator a workable alternative?
Commercial CAN VIN emulators work if they output correct 0x601 and 0x674 frames at 500 kbit/s. Users report mixed success; cheap modules lack required checksum fields
[Elektroda, natal22, post #18964774]
What adapter harness fits when installing into older ISO-wired Renaults?
How do I add rear speakers to the 1-DIN R013PH2 radio?
Rear left: pin 3 (+) & pin 11 (–); rear right: pin 4 (+) & pin 12 (–) on the 20-pin block. Use 4 Ω, 20 W speakers to meet head-unit spec [CarAV Guide, 2023].
What happens if the NOR flash is corrupted?
The MCU halts at boot and the screen stays blank. Reading and reflashing the external NOR with a dump from a working set restores operation
[Elektroda, rtn, post #20401160]
Edge case: what if VIN write fails mid-process?
Can I fully disable antitheft checking?
