Wsk 125 - CDI ignition - no battery after connecting the battery
info-tech 12417 5
  • #1 16524909
    info-tech
    Rate: 88
    Hello, I made a CDI ignition according to the instructions of my colleague Szymon and post viewtopic.php? F = 118 & t = 17870
    everything worked motorek rode and it was ok until connecting the battery. I connected the battery and before firing, the lights, horn and ignition went on until I tried to fire. After kicking the kick, the motor did not start, the lights and horn ceased to operate. Before I connected the battery, I measured the voltage and polarity on the cables to the battery and there was about 18 volts DC without load, I also connected the polarity well. After this damage, I noticed that the ignition module is warm as well as the battery and cable + as I touch the battery it is sparking or shorting. My question is what could have broken down and what could have been the reason for the fault.
    Diagram of my installation below.
    • Wsk 125 - CDI ignition - no battery after connecting the battery IMG_0013.JPG (92.71 KB) You must be logged in to download this attachment.
  • #2 16525934
    BANANvanDYK
    Help: 1167
    Rate: 2602
    Is battery voltage not extinguished on the module extinguishing cable? This is the only explanation. Did you check how you connected the ignition switch?
  • #3 16526207
    web69
    Help: 188
    Rate: 629
    And where does 18V come from? Good meter?
  • #4 16527172
    info-tech
    Rate: 88
    18 volts but I measured it. No load. I don't know with the ignition. But when I used a motor without a battery, the lights were long, short, the horn turned off.
  • #5 16528992
    info-tech
    Rate: 88
    A small fix. I replaced the regulator and the engine starts. I noticed how the ignition is on extinguishing there is a short on the cables that go to the battery. In turn, when I start the motor, the battery cables have a constant voltage of 30 V. Anyone got an idea for this?
  • #6 16529627
    BANANvanDYK
    Help: 1167
    Rate: 2602
    Checking the "charging voltage" without a battery is pointless.
    If the regulator has "sense" input, then its input must be supplied with voltage "after the ignition". Without it, the regulator will overcharge the battery. However, the Chinese can make a pipe sense cable, and inside connect them directly to the battery - such a regulator steals the battery current at a standstill.
    Make sure you connect the ignition switch.
