WSK 125 Battery - Best Capacity, Brand & Price Options for WSK 125 Motorcycle
Darekko31 13920 5
  • #1 16612968
    Darekko31
    Hello everyone,
    I have some more points, so I will use them because I have a problem and the experience and knowledge of forum members is huge that I can be sure that my doubt will be dispelled in a few moments :)
    I want to buy a battery for WSK 125, I'm thinking about the choice, because for my taste the larger the capacity, the better but probably worse with charging such a bastard, moreover, a large capacity is probably not needed for the stop, horn and any direction indicators (which I want to make LEDs have more peace of mind). The most important is which company? Buy cheap or spend more money? Again, we are coming back to whether it makes sense to charge a battery for PLN 100 or if some WM Motor for PLN 55 is enough.
    stanislaw1954
    Help: 2013
    Rate: 4675
    Because the battery does not play a major role in this vehicle, there is no starter, so the quality of the battery does not matter. It is important to take care of him during the dead season - winter.
  • #3 16613076
    Darekko31
    That's exactly what I thought :) Thanks a lot buddy. Is it worth making a voltage stabilizing system at 6V or do you want to break it and use only a diode?
    stanislaw1954
    Help: 2013
    Rate: 4675
    In these motorcycles, as I remember, there was a selenium rectifier, which was sufficient in normal operation. It seems that from the charging coil in WSK you can not get too high voltage threatening the battery, so there is no point in thinking of a voltage stabilizing system.
  • #5 16613181
    Darekko31
    as I said :) A moment of time and all doubts dispelled :) Thank you very much.
  • #6 16614034
    tzok
    Help: 3176
    Rate: 6549
    However, if you replace the selenium rectifier with silicon diodes and put on an AGM battery, then some voltage regulator would be useful.
