Land Rover Discovery II 2.5TD5: Issues After Fuel Pump Replacement and Venting Procedure
oldmachine 6045 4
  • #1 16525550
    oldmachine
    hello - the fuel pump replaced - "original" with a basket, valves on the filter housing, heater, regulator.
    venting procedure 5-6 times the engine will start normally, sometimes it doesn't come - it will go and stop the venting procedure again. Can it be through the exhaust gas that gets through the washer between the electro-injectors and the head? or other ideas
  • #2 16525861
    kortyleski
    Help: 957
    Rate: 3860
    It can be like that. Pre-pump running?
  • #3 16526101
    oldmachine
    discovery 2 only has a tank pump, filter with check valves and pressure regulator and injectors, this is a landrower bike not bmw or vw
  • #4 16526318
    kortyleski
    Help: 957
    Rate: 3860
    2.5 td5 has unit injectors, as I remember correctly ...
  • #5 16526337
    oldmachine
    sorry I agree :)
