Land Rover Freelander 1.8 (2002) - Head Gasket Replacement, UPG & Head Planning: Costs & Tips
contactservice 5235 3
  • #1 16838809
    contactservice
    Help: 66
    Rate: 39
    Have any of you made a head gasket on the Landrover Freelander 1.8? Mine is from 2002 and they diagnosed the gasket under the head, i.e. for UPG replacement and head planning plus labor. How much can something like that cost in this model?
    Damian
  • #2 16839081
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    Add the price of new bolts including motor obligatory to replace
  • #3 16839745
    zukmen1981
    Rate: 14
    Check the heads for leaks.
  • #4 16840604
    andexp
    Help: 57
    Rate: 278
    And after disassembling the head, do not turn the crankshaft because the main bearing supports will fall into the oil pan.
