Land Rover Discovery II 2.5TD5 - replacement of washers under the unit injectors
oldmachine 9708 4
  • #1 16528550
    oldmachine
    Hello, I want to replace the washer - the copper seal under the unit injectors and the question is what should be done after replacement? what "play" must there be between the unit injector and the foot? Land Rover Discovery II 2.5TD5 - replacement of washers under the unit injectors
    how many revolutions?
    Added after 24 [minutes]:
    I helped myself :) but I think it will be useful to someone:
    https://www.youtube.com/watch?v=6mYUpF5g-Ss
  • #2 16528627
    moto-kord
    Help: 137
    Rate: 505
    Set the distance
    Crank the engine until the projection on the injector is at its maximum height for cylinder 1
    Turn the adjuster completely clockwise
    Until it stopped
    Turn the adjuster one turn anti-clockwise
    Tighten the lock nut to 16 Nm
  • #3 16555635
    oldmachine
    yes, in addition, I gently milled the contact point between the head and the copper washer and the unit injection and the car goes
  • #4 16556555
    moto-kord
    Help: 137
    Rate: 505
    And applaud you.
  • #5 16556789
    oldmachine
    this applause me :)
