Connecting a Resistor: Soldering Techniques, Direction, and Rules for Options 1, 2, and 3
nigraS 18495 4
  • #1 16528420
    nigraS
    Rate: 17
    Do you need to stick to any soldering resistors or whether in which direction they are soldered? Connecting a Resistor: Soldering Techniques, Direction, and Rules for Options 1, 2, and 3
    Option 1, 2 and 3 shown in the figure above.
    (I hope I conveyed it clearly)
    sosarek
    Help: 9318
    Rate: 15494
    All are parallel connections, no polarity.
    Z
    Pka, Poznań, 60-850
    Kaliber PC - Service
    Help: 50
    Rate: 69
    With resistors there is absolutely no difference how they are connected (i.e. as a colleague pointed out above), you only need to pay attention to the power and choose depending on the needs in the system.
    Konstantego Damrota 5, Radlin, 44-310 | Tel.: 692XXXXXX (Show) | Company Website: https://www.kaliberpc-service.pl/
    _jta_
    Electronics specialist
    Help: 3202
    Rate: 4216
    But if you solder in different directions, and then you will watch the plate to see where it is, you will have a difficult task.
    Help: 50
    Rate: 69
    Good point too :D
    Searching nearby - recently I had to review the system that I designed last year ... processor and mass of SMD components, and the schematic got lost somewhere. Deciphering all the "secrets" took far too much time (and it was soldered as you noticed rather anyhow, i.e. the markings were on all sides of the world), so ... yes, it is definitely worth paying attention to the soldering method itself ;) That's the story there, thank you. ^^
