Current Flow in Redrawn Circuit for Finding R—Which Diagram Is Correct?
324 13
  • #1 21663101
    Steve Lawson
  • #2 21663102
    Steve Lawson
  • #3 21663100
    Shri Nidhi
  • #4 21663103
    Shri Nidhi
  • #5 21663104
    Shri Nidhi
  • #6 21663105
    Shri Nidhi
  • #7 21663106
    Kvks kumar
  • #8 21663107
    Earl Albin
  • Thevenin and Norton reduction to find R
    #9 21663108
    Earl Albin
  • Current direction choice only changes sign, not magnitude
    #10 21663109
    Geraldo Lopes Serodio
  • Loop analysis shows fig 3 is correct
    #11 21663110
    David Adams
  • #12 21663111
    Earl Albin
  • #13 21663112
    Earl Albin
  • Questioning current directions in the redrawn circuit
    #14 21663113
    Shri Nidhi
The discussion centers on determining the correct current flow direction in a redrawn circuit used to find an unknown resistance R. The original circuit (Fig:1) was redrawn (2nd Fig) for simplification, but the current direction proposed by the user aligns with that shown in the 3rd Fig. Multiple contributors confirm that the current direction in Fig 3 is correct, noting that the sign of current in circuit analysis indicates direction but does not affect magnitude. The problem involves applying circuit simplification techniques such as Thevenin and Norton equivalents, voltage dividers, and loop analysis. Calculations show R to be approximately 5.38 Ohms. The discussion emphasizes the importance of simplification methods over mesh equations for quick insight and solving, and clarifies that the current direction assignment is a convention that can be corrected by sign interpretation in equations. The user acknowledges unfamiliarity with Thevenin and Norton theorems but recognizes their utility after reviewing the explanations.
TL;DR: The correct redrawn diagram is Figure 3, and the solved value is R ≈ 5.38 Ω; “simplify, simplify, simplify.” [Elektroda, Earl Albin, post #21663108]
Why it matters: This FAQ helps students and hobbyists quickly decide current direction and compute R using Thevenin/Norton without overcomplicating homework-style circuits.
Which redrawn circuit has the correct current direction?
Figure 3 is correct. It matches loop relationships that lead to a solvable set without sign conflicts, confirming the chosen current polarities. [Elektroda, David Adams, post #21663110]
What is the final value of R in this problem?
R ≈ 5.38 Ω. Using simplification and source transformation yields a node voltage near 5.38 V across a 1 A branch, so R = 5.38 Ω. [Elektroda, Earl Albin, post #21663108]
How can I solve for R fast using Thevenin?
  1. Form a Thevenin for the 12 V, 10 Ω, 1 Ω side: Vth ≈ 10.91 V, Zth ≈ 0.91 Ω.
  2. Add the 2 Ω in series: Zs ≈ 2.91 Ω feeding 6 Ω || R.
  3. Solve the node current/voltage, then compute R = V/1 A ≈ 5.38 Ω. [Elektroda, Earl Albin, post #21663108]
Can I use Norton instead of Thevenin here?
Yes. Convert to a Norton source: In ≈ 3.75 A with ≈ 1.95–1.96 Ω in parallel. Subtract the known 1 A branch to get Ix, compute node voltage, then R = V/1 A ≈ 5.39 Ω. [Elektroda, Earl Albin, post #21663108]
Do I need mesh equations to solve this?
No. Loop insights suffice. One post lists four loops but shows you can solve using relationships and simplification instead of full mesh equations. [Elektroda, David Adams, post #21663110]
Does choosing the “wrong” current direction ruin the answer?
No. If your assumed direction is opposite, the solution returns a negative current. The magnitude remains correct; flip the arrow to fix direction. [Elektroda, Geraldo Lopes Serodio, post #21663109]
Why do experts stress simplification first?
It gives quick insight and fewer equations. As one expert put it, the key is to “simplify, simplify, simplify.” This often outperforms brute-force meshes on paper. [Elektroda, Earl Albin, post #21663108]
Where is the voltage divider in this circuit?
Across the 12 V source, the 10 Ω and 1 Ω act as a divider. Their reduction produces Vth ≈ 10.91 V with Zth ≈ 0.91 Ω for the left side. [Elektroda, Earl Albin, post #21663108]
What are Thevenin and Norton equivalents in plain terms?
They are simplification tools. Replace a network by a single source plus an equivalent resistance to make hand analysis faster and clearer. [Elektroda, Earl Albin, post #21663111]
How do the 10 Ω and 1 Ω resistors affect the source seen by R?
They set the Thevenin pair for the left network: Vth ≈ 10.91 V and Zth ≈ 0.91 Ω. That then combines with the 2 Ω series path before the 6 Ω || R load. [Elektroda, Earl Albin, post #21663108]
Can Kirchhoff’s rules and SPICE confirm this result?
Yes. Kirchhoff-based equations are how SPICE solves circuits. They confirm the simplified approach and the R ≈ 5.38 Ω outcome. [Elektroda, Earl Albin, post #21663111]
Someone said “No right.” What’s the final consensus?
Later posts resolve the ambiguity: Figure 3’s current directions align with the solvable loop set and yield the correct R value. [Elektroda, David Adams, post #21663110]
