Peiying PY-GPS5012 Unlock Guide: Update Navigation Maps, Fix Shortcut Disappearance Issue
lukasmrgl 5802 2
  • #1 16336855
    lukasmrgl
    Hello everyone, I have a problem with navigation. I uploaded a new map to the microsd card and the automap works fine but after disabling navigation the shortcut from the desktop disappears and I have to create it again. How to fix it?
    japycz321
    Help: 92
    Rate: 141
    If you have unlocked the map to the Windows CE desktop level then it will happen. There are two ways to solve the problem. It is easier to use a panel to start the map, or change the path to the folder where the icons from the desktop are stored in the registry.
  • AutoMapa works by matching original map folder and executable names
    #3 16337115
    lukasmrgl
    Could you develop both ways ??
    Added after 15 [hours] 7 [minutes]:
    I managed.
    I uploaded the auto map onto a memory card
    then I copied it to navi and
    I changed the name of the auto map folder to the name of the original map and
    I changed the name of the file that started the auto map to the name of the original file.
    Everything flashes super and a memory card is not needed if incomplete Europe is involved.
    If you have questions, write.
