Chinese 2DIN Radio: Uploading Maps to Empty GPS Memory Card and Setting Navigation Path
pavel0910 42213 9
How can I restore GPS navigation on an unbranded Chinese 2DIN radio with an empty GPS card slot and no visible setting for the navigation path?
If it is a WinCE-based unit, put AutoMapa on the SD card, then connect the radio to a computer and change the GPS link so it points to the AutoMapa executable on the card [#15847992] If the device is only a Chinese pseudo-system and the mini-USB port is not recognized by the computer, there may be no way to change the navigation path from the outside [#15847776][#15848940] In that case, the only practical advice given was to get information from the seller/manual, because the thread never identified the exact navigation executable or configuration screen [#15848987][#15848992]
  • #1 15847761
    pavel0910
    Rate: 12
    I bought a Chinese 2din radio. Everything works great, only the place for the GPS memory card was empty. I installed the automation on the memory card, but it does not work. On the radio I need to give the navigation path, but it's nowhere in the settings. It is a total Chinese, no symbol, no model on the housing. There are also no information about the equipment in the settings.
    That's how the radio looks like.
    There is a chance to do something about it?
  • #2 15847769
    ShakeAll
    Help: 29
    Rate: 135
    basic question, Windows, Android or some Chinese pseudo system?
  • #3 15847771
    pavel0910
    Rate: 12
    I do not know, I can not figure it out. No sticker with a license for windows is available. It looks like a Chinese system.
    There is an SD card slot described as GPS. Apparently someone has previously ridden a lot on this GPS ...
  • #4 15847776
    ShakeAll
    Help: 29
    Rate: 135
    maybe this is just an overlay on the old WINT and then the matter is very simple, but if it's a Chinese pseudo system then I'm afraid it's swept.
    Is it possible to connect with a computer via usb?
  • #5 15847778
    pavel0910
    Rate: 12
    And if it was an overlay, what would you do next?
    At the front of the radio there is only a mini usb connector. I have not tried to connect it to the computer yet.
    ShakeAll
    Help: 29
    Rate: 135
    In the case of WinCE, you prepare AutoMapa on the SD card, then connect the radio to the computer and check where it directs the link described as GPS and if necessary change it to lead to AutoMapa on the card.
  • #7 15848940
    pavel0910
    Rate: 12
    I connected this radio via USB to my computer, but it does not detect it in any way.
  • #8 15848987
    ShakeAll
    Help: 29
    Rate: 135
    try to get some information from the seller
  • #9 15848992
    pavel0910
    Rate: 12
    Contact has stopped, nothing can be done.
    Added after 2 [hours] 50 [minutes]:
    I undressed this radio. Inside I found GS-817 markings. Putting this in the search engine, I found something like that.
    http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=123171&whichpage=9
    Unfortunately, I still do not know how to set the navigation path or what the original file is called. You can not set this path anywhere.
  • #10 15857348
    pavel0910
    Rate: 12
    I came to the conclusion that the GPS module is SACGM1002 - v.1.0
    It still has a black screen when you turn on the GPS.
    I understand that windows CE is saved in this GPS module? And the whole radio works on another system?
    Is it possible to solder USB to this module and connect via Active Sync?
The discussion revolves around a user who purchased a Chinese 2DIN radio with an empty GPS memory card slot. The user attempted to install navigation software (AutoMapa) on the SD card but faced difficulties in setting the navigation path due to a lack of identifiable system information. Responses suggest checking if the system is Windows CE or a Chinese pseudo system, with recommendations to connect the radio to a computer via USB for further investigation. The user later discovered internal markings (GS-817) and identified the GPS module as SACGM1002, but still struggled with navigation path settings and connectivity issues.
