[Solved] Lenovo G580 Laptop RAM: Identify the Type (DDR1/2/3), Speed, and Compatibility for Additional 4GB
dorsz0591 12003 9
How can I identify the RAM type and speed in a Lenovo G580, and can I add another 4 GB module that will be compatible?
Your Lenovo G580 uses DDR3-1600 SO-DIMM RAM, and you can add a second 4 GB stick if it matches the existing module, preferably the same 1600 MHz type [#16533066] [#16533200] Check the markings on the RAM module itself; the posted Ramaxel part number RMT3160ED58E9W links to a DDR3-1600 module [#16530855] [#16531276] The forum answer also notes that compatible modules can be either 1.35 V or 1.5 V [#16533438] So the listed 4 GB PC3-12800S module should fit and work in the G580 [#16533066] [#16533200]
  • #1 16530846
    dorsz0591
    Rate: 30
    Hello, I have a Lenovo G580 laptop and I have a question about RAM.
    I have a 4GB RAM bone in my opposition but I don't know if they are DDR1, 2 or 3 and what speed they have.
    How can you check it?
    And how to check if I can add another 4 to my 4GB. There are two places so you can physically but can the card cope with it.
    I downloaded the CPU-Z program but it did not show what framework I have but their size
    sosarek
    Help: 9320
    Rate: 15532
    Z
    Pka, Poznań, 60-850
  • #3 16531234
    dorsz0591
    Rate: 30
    The following inscriptions appear on the card:
    RAMAXEL NB851211019 100280253 12444A 4GB HT
    11511200393ACA4920016 RMT3160ED58E9W
    I can read from it that the bone has 4GB of RAM and nothing else :)
    And the question is whether if I add a second identical bone, will the card embrace it?
  • #5 16533022
    dorsz0591
    Rate: 30
    I looked through and thank you for your help but I admit that I can't speak English and I can't understand if I can add another 4gb of RAM or not
    rtj71
    IT specialist
    Help: 474
    Rate: 353
    DDR3 1600MHz, you can insert a second bone, preferably the same (and certainly 1600MHz).
  • #7 16533164
    dorsz0591
    Rate: 30
    So can I order such and will fit 100%?
    ramaxel-4GB pc3-12800s-rmt3170eb68f9w-g-24 innovation with
    Sorki, that he asks so many questions but I don't know much about it :)
    rtj71
    IT specialist
    Help: 474
    Rate: 353
    Yes, you can buy it.
    sosarek
    Help: 9320
    Rate: 15532
    Just pay attention to what voltage the memories work, in the first link you have information that is compatible - on 1.35 or 1.5V.
    Z
    Pka, Poznań, 60-850
  • #10 19655487
    dorsz0591
    Rate: 30
    purchased in a shop - I had my laptop with me
The discussion revolves around upgrading the RAM in a Lenovo G580 laptop. The user seeks to identify the type and speed of their existing 4GB RAM, which is confirmed to be DDR3 at 1600MHz. They inquire about the compatibility of adding an additional 4GB RAM module. Responses indicate that it is possible to add a second identical RAM stick, preferably with the same specifications (DDR3 1600MHz). Users are advised to check the voltage compatibility (1.35V or 1.5V) before purchasing the new RAM module.
