Lenovo G780: Compatibility of 1.35V RAM & Official Support List (Max 8GB, DDR3 1600)
2025 3
  • 1.35v ddr3 modules are compatible
    #1 20442484
  • DDR3L modules usually work at 1.5 V too
    #2 20442547
    dt1
    Admin of Computers group
    Help: 7320
    Rate: 8306
    DDR3L memories should work even with memory controllers that didn't support them - usually these memories tolerate 1.50V power supply (although it's worth checking the specification if possible).
    In the case of 3 gen core, it doesn't matter whether you put in DDR3 or DDR3L - both types will work (although it's best not to mix them). Gen 2 should also work on both, although it officially supports DDR3 (without L, for higher voltage, but as I wrote - L-ka will most often tolerate if you power it with higher voltage, so it will also work in practice, probably everything).
  • #4 20442760
    dt1
    Help: 7320
    Rate: 8306
    Dedication doesn't matter, buy a processor that will handle it. If the dedication does not increase the amount, then why not.
