[Solved] Evaluating the Cost-Effectiveness of Warsaw Scaffolding Frames from Leroy Merlin
rufus239 7773 10
Is it worth buying 8 Warsaw scaffolding frames from Leroy Merlin instead of a cheaper package or renting them?
It is worth buying them only if you will use the scaffolding often and have somewhere to store it; otherwise the more expensive package or rental may not pay off [#16534728][#16534916][#16534970] You already calculated that the Leroy Merlin frame price is about 45 PLN, while the other offer is 32 PLN per frame but 160 PLN per package, so the overall cost can be higher than it first looks [#16534728][#16535889] For home use, an “eco” scaffolding should be enough [#16534740] Before buying, check the quality details, especially the tube diameter and wall thickness [#16534733]
  • #1 16534695
    rufus239
    Level 4  
    Rate: 16
    Hello!
    I plan to buy 8 Warsaw scaffolding frames from Leroy Merlin. I just wonder if it's worth?
    The scaffolding frame costs around 45 PLN. Alledrogo cancer costs about PLN 32 but the package costs PLN 160 so it won't pay off.
    best regards :)
  • #2 16534728
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    You basically answered it yourself. The package will be much more expensive.
  • #3 16534733
    stanislaw1954
    Help: 2013
    Rate: 4672
    You calculated it yourself, so you know costly. And qualitatively, you need to check, even the diameter and thickness of the tubes.
  • #4 16534740
    rufus239
    Level 4  
    Rate: 16
    This is 'eco' scaffolding also I think that for home use should be enough :)
  • #5 16534916
    jarekm6
    How often will you use such scaffolding? it is better not to use the rental
  • #6 16534961
    rufus239
    Level 4  
    Rate: 16
    Now I have to clean and paint the paneling around the house. Next week, a neighbor's garage to be painted. On vacation, 2 sheds to erect also scaffolding better to be yours :)
  • #7 16534970
    karolark
    Help: 702
    Rate: 2516
    If you have where to keep it better yours.
  • #8 16535889
    Artur k.
    Help: 1279
    Rate: 1701
    Which scaffolding do you mean?
    I found these:
    https://www.leroymerlin.pl/narzedzia-budowlan...-konstrukcyjne-1101-rew-ton,p140890,l700.html
    Only the price is different than what you specified.
    Also, read the comments. :)
  • #9 16535919
    rufus239
    Level 4  
    Rate: 16
    This is half and I mean all only on the site unless it is not
  • #10 16536031
    Artur k.
    Help: 1279
    Rate: 1701
    But this is the Warsaw Scaffolding.
  • #11 16536730
    Bynak
    Help: 31
    Rate: 89
    And all you have to do is scroll down and the following appears:
    link
    Best regards.
The discussion revolves around the cost-effectiveness of purchasing Warsaw scaffolding frames from Leroy Merlin. The user considers buying 8 frames priced at approximately 45 PLN each, while noting that a package from Alledrogo costs 32 PLN per frame but totals 160 PLN, making it less economical. Responses emphasize the user's calculations, the importance of quality checks (such as tube diameter and thickness), and the practicality of owning scaffolding for home projects. Suggestions include evaluating the frequency of use and storage options, with some participants affirming that owning scaffolding is beneficial for upcoming tasks like painting and erecting sheds.
