Orbital Sander: Is Parkside (Lidl) Worth Buying for Canvas Painting? Budget PLN 200 Max
pytlowany1 13299 2
  • #1 17063366
    pytlowany1
    Rate: 91
    What oscillating sander to buy? Budget up to PLN 200 max.
    The intended use of the device is canvas painted canvas for painting pictures. For a smooth surface without cavities.
    Rather small and medium surfaces (30x40 cm, 50x60 cm 100x70 cm).
    Such a grinder is to appear in the Lidl network - is it worth buying?
    https://www.lidl.pl/pl/Asortyment.htm?articleId=12504 " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://www.lidl.pl/pl/Asortyment.htm?articleId=12504
  • #2 17063695
    archanoid
    Help: 76
    Rate: 251
    Hello. I have the same but only with a rectangular foot and I will say that it does the trick. Of course, this is not a grinder to work 8 hours a day, but I pre-sanded the putty with fiber at the metal sheet. Maybe there should be better suction.
  • #3 17063816
    mychaj
    Help: 214
    Rate: 944
    Virtually these grinders are all comparable in durability.
    It is important that you get new feet with Velcro when they are made and stop holding the paper, or maybe adjust the speed because you may not have to tear it at maximum speed.
    And if you have a lot of it, it's worth to be interested in a pneumatic grinder (compressed air drive).
    But you also need a compressor.
