Looking for Small Duroplast Adhesive for Cracked Toilet Seat Repair - Boll, APP, Soudal Alternative
Jacko0o 23187 3
  • #1 17627842
    Jacko0o
    Rate: 49
    I am looking for a duroplast adhesive. I want to glue a cracked toilet seat. On the Trabant forum I read that it sticks together with adhesive and sealants. Boll, APP, Soudal masses were recommended there. However, they are all available in large 300 ml tubes. I need a small package like Super Glue. Besides, for example on Soudal it is written that it is not suitable for PP and EP. I know that duroplast is some kind of polymer, but I do not know what and whether it is PP / PE (?). The sources I found say that it is resin + wool or cotton. But Pattex, which doesn't seem to stick to PP / PE / PTFE, didn't catch it ... and now I feel a bit lost ...
    I will be grateful for your help.
    Best regards,
    J.
  • #2 17628617
    jacekko63
    Help: 140
    Rate: 320
    Maybe this one is only 20g:
    Monolith CX 16-5 - bonding thermoplastics and thermosets
    Bonding of thermoplastics and duroplastics.
  • #3 17628877
  • #4 17629799
    telecaster1951
    Help: 829
    Rate: 818
    phantom48 wrote:
    Toilet seats are usually made of PP.
    Do you read the topic at all or do you write for the sake of writing?
    Jacko0o wrote:
    I know that duroplast is a polymer, but I do not know what and if it is not PP / PE (?
    Polyolefins are not thermosets.
    Jacko0o wrote:
    But Pattex, which doesn't seem to stick to PP / PE / PTFE, did not catch it.
    But what Pattex? This company makes a lot of adhesives. These three polymers can hardly be caught by any glue.
    Unfortunately, I don't know what your board is from, you write about a therapist, but I don't know if it's a proper name or not. A material called Duroplast is a phenolic resin with a fleece. Thermosets, in turn, are a group of non-melting polymers with high mechanical properties.
    What is it to stick with? Epoxy resin, polyester resin, Distalem, Poxipol, etc. In other words, we glue duromer with a different type of duromer.
