Top Strong Adhesive Recommendations for Soft Rubber: 15mm Crack, 4mm Thickness, Flexible, High Load
Sajberbob 64809 12
What adhesive can I use to bond soft rubber so the joint stays flexible and can withstand high compression, tension, twisting, and shear loads?
For soft rubber under high flexing and load, the thread points more toward a rubber-specific repair method such as Terokal 2444 or a similar Terokal adhesive, or toward hot vulcanization, rather than Loctite 480. [#11621697][#11622765][#11634728] One reply specifically says Loctite 480 is durable but not suitable for this kind of rubber application. [#11634728] Another suggested using adhesive for car windows, together with the matching glass primer. [#11623697][#11624561] If you can use a patch, a vulcanization shop was recommended, and one person also mentioned adhesives used in fishing waders (Storm). [#11631933] A caution was also raised that if the part is really a bellows or flexible coupling, gluing it may not make sense at all. [#11625245]
  • #1 11621149
    Sajberbob
    Maybe the electrode is not the best place for such a question, but I have not been disappointed with the experiences of my colleagues yet.
    I am looking for a very strong glue to glue soft rubber with. The choice on the market is huge, but I would like something proven, especially since it will probably be expensive ..
    The crack is 15mm wide and the rubber is 4mm thick.
    The joint should be flexible and carry high loads. It will be compressed, torn, twisted (max 15 degrees in 2 planes) and sheared.
    Butapren and Cyanopan E do not stand.
    I am able to spend about PLN 50-100 on glue, but I cannot afford to experiment with a few, so I hope that someone will be able to advise me on something that he used himself and knows that it is worth the price.
    Thank you very much for your help!
  • #2 11621159
    Hucul
    Help: 382
    Rate: 470
    Maybe one of the Loctite products?
  • #3 11621184
    Sajberbob
    Thank you for the quick reply.
    Of course, I was thinking about Loctite (hence the assumption about the price up to PLN 100). But first, I don't know which specific glue to consider; only Loctite 480 appears on the search engine for "gum", which is probably the equivalent of a droplet. And if there is something for everything .. there is probably something better for specific applications.
    And most importantly - I do not have any verified information whether it is really worth the money ..
  • #4 11621316
    Hucul
    Help: 382
    Rate: 470
    Sajberbob wrote:
    ... only Loctite 480 appears in the search engine on their website, which is probably the equivalent of a droplet ...
    Rather, the blob is the cheap equivalent of Loctite. I use 416 and 7452 for rigid joints, where it works perfectly - it can glue well-prepared aluminum surfaces. I know that they used to produce glue for flexible connections a long time ago and it also worked great, it was in the 1980s so there is no chance that I would remember its marking :D
  • #5 11621697
    Adas25
    Rate: 78
    Hello. Read about Terokal 2444 glue, or similar from the Terokal series.
  • #6 11622765
    saskia
    Help: 174
    Rate: 1087
    Or hot vulcanization.
  • #7 11623697
    jacur
    Level 32  
    Help: 166
    Rate: 295
    Adhesive for car windows.
  • #8 11624561
  • #9 11625245
    Artur k.
    Help: 1279
    Rate: 1701
    Show the elements you want to connect and describe what it is for, because it may turn out that no glue can handle it.
  • #10 11628381
    zimny8
    Help: 26
    Rate: 504
    Use droplets, super glue, gum glue doesn't need to be flexible, rubber is elastic, and that's enough.
    It is probably the sole of a shoe, so each gluing will last for a short time, you can buy new shoes for a hundred.
  • #11 11628788
    Artur k.
    Help: 1279
    Rate: 1701
    The sole of the shoe is rather not squeezed, torn, twisted and sheared. It is rather some elastic element, e.g. a bellows, or some kind of flexible coupling.
    If so, gluing such elements does not make any sense.
  • #12 11631933
    cezar80
    Help: 94
    Rate: 67
    It all depends on what is to be glued. Butaprene is good for rubber. However, if you can give a patch, I recommend a vulcanization plant. They also have great adhesives in fishing waders (Storm)
  • #13 11634728
    empella
    Loctite 480 is not suitable for this type of application. It is very durable, but unfortunately it will not work with rubber. A few years ago I was gluing 4860 tubulars. Holes with a diameter of 4-5 mm are easily glued. At the same time, it worked with the entire tubular and withstood 8 bar.
    Regards
The discussion centers around finding a strong adhesive suitable for bonding soft rubber with a 15mm crack and 4mm thickness, requiring flexibility and high load-bearing capacity. Users suggest various adhesives, including Loctite products, specifically mentioning Loctite 480 and 4860, although concerns are raised about their suitability for rubber. Alternatives like Terokal 2444 and hot vulcanization are recommended, with some users advising against gluing if the application involves significant movement or stress. The importance of using well-prepared surfaces and considering the specific application context is emphasized, as well as the potential for using professional vulcanization services for optimal results.
