Samsung S5 Neo - No Power After Call, Charging Unresponsive, Battery Icon Displayed
rekordgsm 6054 5
  • #1 16540884
    rekordgsm
    Help: 159
    Rate: 112
    Hello, we have s5 neo, after the end of the call, the phone turned off, at the moment no reaction to charging, only the battery icon appears after turning on.
  • #2 16541057
    marcin7904
    Help: 138
    Rate: 257
    Try with battery replacement. I had similar symptoms with S4. The phone did not turn on when I connected the charger, zero response, also showed only the battery icon. I replaced the battery and the phone came to life.
  • #3 16541130
    rekordgsm
    Help: 159
    Rate: 112
    On the second battery, I wrote the same wrong, maybe in the previous post, without connecting to the charger, only after pressing powera the battery icon appears.
  • #4 16720256
    luxxxus
    Help: 31
    Rate: 8
    Has the problem been resolved? I have an identical case.
  • #5 16725155
    Stokłosy
    GSM specialist
    Help: 276
    Rate: 72
    I would charge the batteries. He took out and inserted the batteries. He pressed the key combinations as for download. And he put the usb cable in the socket. Changed soft.
    For example, the newest without brand for today:
    Country / Region Poland
    PDA G903FXXU1BQC1
    Product Code XEO
    CSC G903FOXA1BQC1
    Phone G903FXXU1BQC1
    6.0.1 Marshmallow (Android) / March 21, 2017
    If there is still a partner. Then try hard reset the key combination after the software. After inserting and removing the battery. And soft again. It helped me once.
  • #6 16796868
    rekordgsm
    Help: 159
    Rate: 112
    The phone enters download mode, unfortunately it is not detected by the computer. The second tape with a USB connector was also replaced, with no effects.
