Samsung Galaxy S5, S6, S7 - A common error of the blue LED in Samsun flagships
thelukios 23331 7
  • #1 16887829
    thelukios
    Rate: 15
    Hello, I have a question about the error of the blue diode. It consists in the fact that the phone turns off at a certain moment and the blue LED is still lit, sometimes it is pulsating but only in the blue color. The phone after this incident does not want to turn on again. It happened to me and in the following weeks from the end of October with 4 of my friends (s6 x2, s6 edge, s5 neo) today a friend's phone fell and I decided to find out what the problem was. With one friend after trying to activate recovery, the phone normally works (until now) but in other cases the phone has not turned on. How can I diagnose a problem?
    Thanks in advance and regards
  • #2 16889648
    Andrzej Ch.
    Help: 222
    Rate: 387
    I have been Samsung Galaxy S5 for over two years and have never encountered such a problem. I think this problem IS NOT PERSONAL in Samsung Galaxy S5
  • #3 16889870
    thelukios
    Rate: 15
    I wrote S5 neo in the description, it's possible that neo has a renovated architecture that is flawed. I have no idea.
  • #4 16889881
    Andrzej Ch.
    Help: 222
    Rate: 387
    The header is S5 (without neo)
  • #5 16889932
    thelukios
    Rate: 15
    because it did not fit; p
  • #6 16894589
    blade1231
    Help: 8
    Rate: 31
    The battery has died. Or rather, it gets too deep or the phone has a hinge and you have to do a reset. 10 seconds hold down vol down + home button
  • #7 16989035
    lukaszzet
    Rate: 29
    I just got unloaded and I have a similar problem pulsing blue LED, or in the gre go only replacement battery?
  • #8 17268409
    thelukios
    Rate: 15
    On the site they said that the cold solder was made on the motherboard
✨ The discussion revolves around a recurring issue with the blue LED indicator on Samsung Galaxy S5, S6, S6 Edge, and S5 Neo devices, where the phone turns off while the blue LED remains lit, sometimes pulsating. Users report that after this incident, the phones often fail to power on again. Some suggest that the problem may be related to battery failure or a deep discharge, while others mention the possibility of a cold solder issue on the motherboard. A few users have successfully revived their devices by performing a reset using the volume down and home button combination. The problem appears to be common among multiple users, indicating a potential design flaw in the affected models.
