Elektrolux EWF1445 Washing Machine: Error E51, Impeller Block & Service Mode Inquiry
amm 12091 12
How do I enter service mode on an Electrolux EWF1445, and what could be causing error E51 after the pump was cleaned?
To enter service mode, hold EXIT and START, then turn the program knob one step to the right; the display should start flashing the symbols in sequence [#9621997] For E51, replies point to checking the door switch, moisture or dust inside the machine, and the wiring/contacts around the heater and motor, especially the heater ground wire if it is not fully inserted [#9621997][#11653704][#14344465] One user also found a clogged drain hose causing similar symptoms, so the drainage path should be inspected too [#9712174] Another reply says E51 may clear after the machine is unplugged for about two hours [#11653893] A later reply attributes E51 to the BTB16 700BW triac, but that was mentioned as a replacement/part fault rather than a confirmed general fix [#18662738]
  • #1 9413678
    amm
    The washing machine went OK until one day it stopped pumping water, I dismantled both pumps, it turned out that one was blocking the impeller, I cleaned it, I checked, it works, I assembled the washing machine and the code E51 appeared after switching on. I have a question, maybe someone knows what to do next because I don't know how to enter the service mode and what the code is about
  • #2 9614393
    KBRoman
    I also have a problem with the 1445 washing machine and I do not know how to enter the service mode.
    The washing machine starts washing and in a moment pushes out the water and the end.
  • #4 9621997
    amm
    Entering service mode:
    Press and hold exit and start, then turn the program dial to the right.
    Such symptoms are caused by:
    1. Switch next to the door; it should be disassembled and cleaned as a last resort replaced
    2. Moisture inside the washing machine; I removed the top flap and "vacuumed" well and ventilated the wires, engine, etc., and for now it works.
    The mechanic who arrived spread his hands and could not diagnose the fault
    even though the washing machine displays codes. However, from what I could orientate the washing machine is very sensitive to weakening insulation on electrical components and you have to grope
    Good luck and best regards
    PS.
    If you find something, write, because with this washing machine there is nothing to count on services ...
  • #5 9622571
    szymon_8511
    Rate: 17
    KBRoman switch to the spinning itself and see if the washing machine moves with the drum - it will go into rotation. If not then check the brushes on the engine, if so there are still several options.
    As for the errors in washing machines, even in the manufacturer's service cards half of the messages are described in the "communication error" style ...
  • #6 9711373
    amm
    Hello, thanks for the advice
    I waited until I waited
    the washing machine comes into rotation when spinning
    the problem remained
    I wonder if dust from brushes and other dust have no effect on the washing machine's work (or maybe moisture)
    the washing machine worked for a long time without any problems with the upper flap removed
    Greetings and thank you in advance for the tips (such equipment begins to intrigue me more than a ;) computer)
  • #7 9712174
    KBRoman
    For me, the reason was clogging the drain hose. For now it's OK.
  • #8 9865949
    KBRoman
    Welcome back!
    My EWF 1445 washing machine broke down again.
    This time it looks like this:
    - in the washing programs, after a while, drainig 0 0 is displayed and the program ends right.
    - on programs rinsing and spinning everything works ok.
    I entered the diagnostic mode by pressing the exit and start buttons and by turning the knob one time to the right (clockwise), all the symbols started flashing on the display in turn.
    After a moment I turned the knob once again to the right, the words Diagnostic test 21 appeared
    underneath load: Wash 0 - the washing machine has drawn water to half of the drum and nothing else has happened (I pressed different buttons then different numbers appeared instead of zero)
    I turned right again and the message diagnostic test 13 appeared underneath load prewash 0
    After a while, errors appeared
    MB ALARM E35 and UJ ALARM E95
    I turned the machine once more and took the water to the middle of the drum. subtitles with errors all the time on the display.
    I turned the knob to position 0.
    Once again, I pressed the exit and start and turned the knob to the right, the inscription Elektric test appeared and the washing machine full of water began to rotate the rotor left and right, after about 10 minutes I finished this test.
    Does anyone know what can be my washing machine?
    I did the diagnostic test on the fourth position of the knob and there were errors
    MB ALARM E35 and UJ ALARM E93
    I once again released the Electric test program (this time with a smaller amount of water)
    After completion, the message Warning E61 and see instruction booklet appeared
  • #9 10291027
    PKi
    Help: 8
    Rate: 139
    Similarly to me, EWF 1045, some sock got under the apron between the drum and the tank and blocked the drum. After removing the sock, the drum rotates freely. After attaching E51.
    After holding START, EXIT shows E51 and E95
    Who will help?
  • #10 11653704
    amm
    Welcome back.
    An old topic, but maybe it will help someone and fail again, symptoms as in the following posts;
    I took apart, cleaned dust from dust, cleaned insulation on wires (it was dusty), etc. I checked preventively for brushes being suspended
    and I found the ground wire next to the heater, which was not fully inserted
    probably this was the reason for the failure (the washing machine has an extensive electric shock protection system and the lack of a good grounding signal of the heater could cause a failure).
    Best regards and good luck.
  • #11 11653893
    PKi
    Help: 8
    Rate: 139
    For me, this E51 could be removed over time, as I remember after two hours without power it helped.
  • #12 14344465
    apartament2
    Washing machine Elektrolux EWF 1445
    Error Code:
    eMB E52
    Error code table for Elektrolux EWF 1445 washing machine with explanations for codes E51-E55 and repair suggestions.
    UI E98 (I did not find the error code marking)
    The washing machine engine did not start. After opening the washing machine and cleaning the coal dust of wire harnesses, contacts (especially around the engine), the washing machine began to function properly.
  • #13 18662738
    sakull78
    PKi wrote:
    For me, this E51 could be removed over time, as long as I remember after two hours without power helped.
    This error E51 is a replacement of the BTB16 700BW triac.
    I have a washing machine EWF 12470W
The discussion revolves around the Elektrolux EWF1445 washing machine, which has encountered an E51 error code after the user cleaned a blocked impeller. Various users shared their experiences and troubleshooting steps, including entering service mode by pressing and holding the exit and start buttons while turning the program dial. Common issues identified include moisture inside the machine, faulty door switches, and clogged drain hoses. Some users suggested checking the motor brushes and ensuring proper grounding of electrical components. Others reported that cleaning dust from the machine's internals resolved similar issues. The E51 error may also relate to a triac replacement in some cases.
