Amica AWB 510D Washing Machine: Error E01, Door Lock Issue & Replacement Experience
seel 8412 4
  • #1 16561239
    seel
    Rate: 13
    The washing machine after switching on does not lock the door and after 10 seconds shows error E01, after replacing the bolt / lock with a new one it is the same. Has anyone had this problem?
  • #2 16561546
    Gobro
    Help: 207
    Rate: 503
    You still need to fix the programmer module, blocking control.
  • #3 16562146
    seel
    Rate: 13
    At this stage of switching on, probably other sensors do not block the program. Or maybe some of the forum users have a programmer scheme? Maybe Amica will come alive again. Regards.
  • #4 16562194
    Kenworth 18
    Help: 2442
    Rate: 3749
    Try to reset by disconnecting the washing machine from the mains and then insert the plug into the contact knob to set the washing program and press the START button for a minimum of 5 seconds.
    If that doesn't work, then the module for repair or replacement.
  • #5 16563906
    seel
    Rate: 13
    Unfortunately, the reset does not help. I'm getting into the programmer but it will be hard without a schematic.
