Air Conditioning Factor for Ford Focus 1.8 TDDI 99r - Is AC 950 the Correct Value?
posek 8625 15
How much refrigerant should be filled into a 1999 Ford Focus 1.8 TDDI air conditioning system?
The correct A/C refrigerant charge is 740 g, plus or minus 15 g, not 950 g. The 950 marking on the plate is not the A/C filling amount; the correct quantity should be taken from the manual or the yellow sticker in the engine compartment [#16548331][#16549145][#16549440][#16549665] The system should be recovered and then refilled with the specified amount, because overfilling can cause problems or damage the compressor [#16549666][#16549446]
  • #1 16547620
    posek
    Rate: 32
    Hello. How much air conditioning factor should enter the Ford Focus 1.8 TDDI 3 door hatchback 99r.
    On the rating plate on the front under the hood says AC 950 So much to enter?
    Regards
  • #2 16547625
    piotrekwoj1
    Help: 947
    Rate: 3433
    If it says so it is.
  • #3 16547742
    posek
    Rate: 32
    I read on a certain page, there was a list with Fordes and 750g seems to come to me, now I bought 950g according to the plate and blows perfectly
  • #4 16548331
    hak-2
    Rate: 14
    So you went - ford focus -740g. plus / minus 15g.
  • #5 16548724
    posek
    Rate: 32
    So if you write that the 740 goes in, what does the AC 950 sign mean? I took 950g and cooled perfectly
  • #6 16549145
    milejow
    Help: 1563
    Rate: 5149
    I write like a bull on a plate 0.740kg where did you find 950 ???
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #7 16549395
    posek
    Rate: 32
    Air Conditioning Factor for Ford Focus 1.8 TDDI 99r - Is AC 950 the Correct Value? Please, my plate at the top, you have "like a bull" written 950kg - it is possible that this value applies to something else, 2 years ago when I was filled with atmosphere in the company, it also filled 950g and suggested this plate. The air conditioning switches on normally, cools almost immediately, nothing leaks, nothing squeaks
  • #9 16549440
    kortyleski
    Help: 957
    Rate: 3860
    I am to understand that you hit 950 kg refrigerant according to the table? Cheek boy. Until I reach the calendar, make sure that today is not the first of April ... The amount of refrigerant determines the YELLOW sticker in the engine compartment. Possibly a vehicle manual, but why read it?
    posek wrote:
    , 2 years ago, when I got a vibe in the company, it also filled 950g and suggested using this plate.
    Tell him to switch to beet trade. I will write less.
    You have a factor of 740 grams. In the current situation, the heat will come and stop cooling or you will kill the compressor
  • #10 16549446
    jack63
    Help: 851
    Rate: 2822
    Good, really brilliant. The service will not consume as many kilograms of the factor for a year.
    Expect problems. System overfilled.
  • #11 16549652
    posek
    Rate: 32
    I counted on tons of hate, as it happens on the electrode, so you suggest to pump the factor and fill 740 g?
  • #12 16549665
    andrzej20001
    Help: 1578
    Rate: 6669
    No hate but advice. It must be as in the instructions and not as in the "sticker"
  • #13 16549666
    jack63
    Help: 851
    Rate: 2822
    posek wrote:
    I counted on tons of hate, as it happens on an electrode
    Are you a masochist, or do you think that paying attention to someone can only get a tumor? Cooling systems are FILLING.
    The refrigerant should be RECOVERED and then filled with the correct amount of refrigerant. I assume that there is no air in the recovered medium. The arrangement is tight and vacuuming will be done.
  • #14 16549880
    posek
    Rate: 32
    There is an old proverb "man learns from mistakes" you have probably committed them yourself. On Monday I will go under the machine and let me fill as much as I need. Thank you for the advice
  • #15 16549909
    jack63
    Help: 851
    Rate: 2822
    Just out of curiosity. You made this tumor yourself :D ?
  • #16 16550235
    posek
    Rate: 32
    Also out of curiosity: You have bought these 5248 posts by catching someone?
    I consider the topic closed
The discussion revolves around the correct air conditioning refrigerant charge for a 1999 Ford Focus 1.8 TDDI. The user inquires about the AC factor indicated on the rating plate, which states 950 grams. Responses vary, with some users suggesting that the correct amount should be around 740 grams, as per standard guidelines. Despite the discrepancy, one user reports successful cooling with the 950 grams filled. Others caution against overfilling, warning that it could lead to compressor damage or system inefficiency. The consensus leans towards adhering to manufacturer specifications rather than the rating plate's indication.
