BRIGGS & STRATTON 375 engine - the gap between the coil and the flywheel.
mooglie 27783 8
  • #1 16548726
    mooglie
    Rate: 22
    Hello. I decided to repair the petrol lawn mower myself and it turned out that the ignition coil was dead. I bought and installed the ignition coil, but there is one problem! I do not know what gap to set between the coil and the magnet (magnet?) I am asking for advice.
  • #2 16548789
  • #3 16549053
    mooglie
    Rate: 22
    the video was ok! but I was learning another language. maybe some other hint?
    Added after 34 [seconds]:
    the gap of 0.4 mm will be not too small
  • #4 16549302
    Krzys55
    Help: 89
    Rate: 303
    0.4 positions itself on the candle. This is definitely not enough.
  • #5 16549537
  • #6 16549548
    kortyleski
    Help: 957
    Rate: 3860
    The pause as small as possible, as long as the wheel does not rub against the pole pieces.
  • #7 16549558
    E8600
    Help: 529
    Rate: 2520
    A feeler gauge would be the best, but a thicker piece of paper is enough to prevent problems.
  • #9 16556785
    mooglie
    Rate: 22
    I would like to thank Rycho T. The given dimensions were very useful, the best dimension of the gap between the magnetic wheel and the coil is 0.23 mm. The engine works flawlessly.
    Thank you for all your help and best regards. "mooglie"
The discussion revolves around setting the correct gap between the ignition coil and the flywheel for a Briggs & Stratton 375 engine after replacing a faulty ignition coil. Various responses suggest a gap of approximately 0.4 mm, with some users recommending a range of 0.06 to 0.14 inches (or 0.15 to 0.35 mm) as optimal. A follow-up from the original poster confirms that a gap of 0.23 mm resulted in the engine operating flawlessly. Tools such as a feeler gauge or a thicker piece of paper are suggested for measuring the gap accurately.
