Briggs 5 HP 206cc Engine: Repairing Spark Loss, Coil-Module Internal Puncture & Compatibility
cyborg39 13017 10
Why does the cable enter the engine on this old Briggs 5 HP engine, and can the ignition module be replaced with one from another engine?
The cable is part of the ignition cut-off/kill circuit or the old breaker-type ignition, so disconnect it first to see whether it is grounding the ignition and blocking the spark [#10795169][#10798566] In this old Briggs engine there can be a chopper/breaker and capacitor under the flywheel rather than a CDI pickup, and a faulty capacitor, breaker, or a shorted kill wire can cause loss of spark [#10795219][#10799289] In the reported case, removing the cover showed the breaker/chopper, and cleaning and drying its contacts restored the spark [#10801926] If the module really needs replacement, one reply suggests taking the old part to a mower shop to match it, and another says some engines can use an electronic replacement module without the chopper [#10798566][#10798254]
  • #1 10794765
    cyborg39
    Help: 105
    Rate: 546
    I have to repair an old rotary cultivator with a Briggs 5 HP 206 ccm engine. There are no other symbols, the equipment is old and has been painted several times. The engine lost its spark, the owner admitted that he was extinguishing him by removing the pipe from the candle so probably the coil-module has an internal puncture in the HV coil. After removing the case, I noticed that the coil-module comes out of the cable that enters the motor housing, and from the same place comes a different color wire to extinguish. Question - why does this cable enter the engine? Somewhere I've heard of some kind of security brake, is this what it's all about?
    The second question - will the module be able to get to such an old engine? Will it fit from a different engine, newer or larger?
  • #2 10795169
    helena33
    Help: 94
    Rate: 730
    This is an oil sensor, just disconnect the cable from the module and check the spark, if there is a spark you must look for where the fire extinguisher comes in contact with the ground, there may be too little oil and the sensor will disconnect the ignition, or the sensor is damaged, then the engine will half and sensor replacement (or bypassing it from the extinguishing system).
    If it turns out that the spark will not be after disconnecting the extinguishing cable from the module, then the module replacement should be enough :)
    Give a photo of this engine, it will be easier.
  • #4 10795758
    cyborg39
    Help: 105
    Rate: 546
    Exactly, I also thought about the breaker or the impulse in the motor, but it would look more like a sensor. The magnetic wheel is with two magnets, it looks like a typical cewkomodul. I will post the photo later
  • #5 10798057
    cyborg39
    Help: 105
    Rate: 546
    I have engine photos, can anyone look if it's a normal cewkomodul and tell where I can buy one?
    Briggs 5 HP 206cc Engine: Repairing Spark Loss, Coil-Module Internal Puncture & Compatibility Briggs 5 HP 206cc Engine: Repairing Spark Loss, Coil-Module Internal Puncture & Compatibility
    helena33
    Help: 94
    Rate: 730
    However, this model of the motor has a chopper, but there are modules matching this motor without a chopper, you can replace the module with an electronic one.
    Here you have a link to a video with a similar engine and a way to dismantle and replace http://www.youtube.com/watch?v=mvyyf3KJqu4&feature=related
  • #7 10798566
    jack63
    Help: 851
    Rate: 2826
    What breaker ??? After all, it's a typical CDI magnet system used in mowers ...
    First, check that the spark is not blocked by shorting to the ground of the cable you are describing. Just find its end unplug (let it hang) and check the spark on the HV cable itself to ground.
    How not to do this module out to hand and visit the shop with parts for mowers. They should choose something.
    sm48
    Help: 10
    Rate: 57
    This is not a CDI ignition, in the coil there is no third core to trigger the ignition. In old B & S you have a chopper under the flywheel.
  • #9 10799312
  • #10 10799808
    jack63
    Help: 851
    Rate: 2826
    And I would insist on a magnet type ignition. It can be CDI or TCI. Does not matter! It does not require a separate pulser or chopper.
    Well, unless it's a classic spark ignition ... like in Romet.
    You need to find the end of the cable.
  • #11 10801926
    cyborg39
    Help: 105
    Rate: 546
    The case is resolved - however, it is ignited with a chopper. When I took off the lid, it spilled out, the water-drying and cleaning of the chopper's contacts helped. The spark is on, the engine is on but I have to clean the gas. Thank you for all the hints, I close the topic
The discussion revolves around troubleshooting a Briggs 5 HP 206cc engine that has lost spark, likely due to an internal puncture in the coil-module. Users suggest that the cable entering the engine is related to an oil sensor, which may disconnect the ignition if oil levels are low or if the sensor is faulty. Others mention the possibility of a chopper or capacitor under the flywheel affecting spark generation. The author confirms that the issue was resolved by cleaning the chopper's contacts, restoring spark and engine functionality. Recommendations for module replacement and compatibility with newer models are also provided.
