Modifying PARKSIDE PABS 16 Charger for Samsung Li-ion 2600mAh Cells Compatibility
Edward7979 35061 9
Why does the Parkside PABS 16 charger report the battery as full after replacing the original cells with Samsung 2600 mAh Li-ion cells, and can the charger be modified to charge them correctly?
The charger is probably not the main problem; the battery pack’s balancer/management board is likely preventing charging, so the charger reports “charged” because the pack is not accepting current [#16549348][#16549953] Check the battery and individual cell voltages first, because if the pack voltage is around 10 V while the cells are about 3.34–3.38 V each, the charger may be seeing a blocked pack rather than an empty one [#16549348][#16550246][#16550666] One suggestion was to charge the cells manually, one by one, with a bench power supply, since this pack appears to use more complex electronics and possibly I2C communication that can block charging [#16549953] The user found damaged parts on the balancer board, including transistors Q4 and Q5 (LR8726), and later replacing them still did not restore charging [#16550016][#16556735][#16559516] In the end, the practical conclusion was that replacing the balancer/management board was more promising than modifying the charger itself [#16559516]
  • #1 16549280
    Edward7979
    Rate: 18
    After replacing the cells (4 pcs. x 3.7V 2000mAh) in the battery of the Parkside PABS 16 screwdriver with Samsung Li-ion 3.7V 2600mAh cells, the charger does not charge the battery. The cells are properly heated, the battery worked as it should, but I can't charge it. Despite the fact that it is discharged - the charger shows that it is charged (I attach a video). Can this charger be modified in some way to make it work?
    Modifying PARKSIDE PABS 16 Charger for Samsung Li-ion 2600mAh Cells CompatibilityIMAG08..jpg (2.26 MB)You must be logged in to download this attachment. Modifying PARKSIDE PABS 16 Charger for Samsung Li-ion 2600mAh Cells CompatibilityIMAG08..jpg (2.08 MB)You must be logged in to download this attachment. Modifying PARKSIDE PABS 16 Charger for Samsung Li-ion 2600mAh Cells CompatibilityIMAG08..jpg (2.39 MB)You must be logged in to download this attachment.
    Modifying PARKSIDE PABS 16 Charger for Samsung Li-ion 2600mAh Cells CompatibilityIMAG08..jpg (1.77 MB)You must be logged in to download this attachment.
    • FILM1.wmv (30.83 MB) You must be logged in to download this attachment.
  • #2 16549288
    WędkarzStoLica
    Help: 146
    Rate: 300
    Why are these links so heavily unloaded? Maybe there is a reason.
    Try to recharge them one at a time and see if it will move.
  • #3 16549348
    Karaczan
    Help: 869
    Rate: 1127
    If the battery is not accepting current, the charger will also say that it is charged.
    What is the voltage of the battery and individual cells?
    The problem may not be the charger but the balancer in the battery.
  • #4 16549526
    Edward7979
    Rate: 18
    What do you suggest? What to do now? How to recharge these cells? Will it work with a workshop power supply?
    Individual cell voltages:
    3.342V
    3.346V
    3.384V
    3.384V
    Balancer photo:
    Modifying PARKSIDE PABS 16 Charger for Samsung Li-ion 2600mAh Cells CompatibilityIMAG08..jpg (2.25 MB)You must be logged in to download this attachment. Modifying PARKSIDE PABS 16 Charger for Samsung Li-ion 2600mAh Cells CompatibilityIMAG08..jpg (2.29 MB)You must be logged in to download this attachment.
  • #5 16549953
    Karaczan
    Help: 869
    Rate: 1127
    And the workshop power supply, acting as a charger, the current consumption is?
    Charge the cells manually, one at a time, with a workshop power supply.
    I don't know what the system in the balancer means, I can't find the catalog card. It's a bit higher technology than most cheap Li-Ion screwdrivers, because I see I2C there. It is possible that the system does not communicate with the charger and therefore does not charge or is blocked.
    My battery did not charge after replacing the cells with larger ones. The charger claimed to be charged OK. Under the bench power supply, the consumption was always only 70mA. Only a short circuit unlocked it. Giving plus charge to CH+ and minus to B+. Now the battery normally accepts current and charges, connected to CH+ and B-. However, it's simpler electronics without fancy controllers like in your case.
  • #6 16550016
    Edward7979
    Rate: 18
    Making preliminary measurements, the meter shows that the diodes D3, D5, D6 are damaged. I will measure them tomorrow and write what I came up with, because I have to desolder them.
  • #7 16550246
    WędkarzStoLica
    Help: 146
    Rate: 300
    3.342V
    3.346V
    3.384V
    3.384V
    And the meter showed 10 V the whole package, which is about 2.5 V per cell.
  • #8 16550666
    Edward7979
    Rate: 18
    The meter showed 10 between the charging contacts, between the screwdriver contacts it shows 13.44 V.
  • Damaged LR8726 MOSFETs identified for replacement
    #9 16556735
    Edward7979
    Rate: 18
    Yesterday, taking advantage of the moment, I unsoldered diodes D3, D5, D6 and transistors Q4, Q5 to check if they are operational. The diodes are ok, but both transistors are damaged. Q5, after being gently heated and caught with tweezers, fell apart, i.e. its housing. These are N-mosfet LR8726 transistors. I ordered new transistors. I'm waiting for the package. We'll see if replacing them changes anything.
  • #10 16559516
    Edward7979
    Rate: 18
    Unfortunately, replacing the transistors did not help. I have already ordered another balancer. The topic can be considered closed.
The discussion revolves around modifying the PARKSIDE PABS 16 charger to work with Samsung Li-ion 2600mAh cells after replacing the original 2000mAh cells. The user reports that the charger indicates the battery is charged even when it is not, suggesting a potential issue with the charger or the battery's balancer. Various troubleshooting steps are suggested, including checking individual cell voltages and using a workshop power supply to charge the cells manually. The user discovers damaged components, specifically transistors and diodes, during diagnostics. Despite replacing the transistors, the issue persists, leading to the decision to order a new balancer for further testing.
