Asus A555L - does not detect the disk - After replacing HDD with SSD does not de
davede 8436 3
  • #1 16550851
    davede
    I am using a laptop from ASUS, model A555L. Today I decided (not the first time) to replace the HDD with SSD. I cloned everything using the Mini Partition Tool. I replaced the disk and started the laptop. Everything was fine until the first 10 seconds. The laptop immediately after entering the desktop immediately threw BSoD bad_system_config_info and after that it was only worse - the system is impossible to start, it throws me into the BIOS at the moment and most importantly - it does not see any disk. What's more, I tried to cleanly install the system and the installer cannot see any disk.
    To make it funnier, I decided to throw back the old HDD and froze in surprise - the laptop reacts in the same way as with that SSD. He can't see the disk, can't do anything with it, only enters the BIOS.
    Could it be that I broke something while mounting the disk? In general, nothing was complicated there. I removed the tape from the disk, unscrewed the plate on the right and left of the disk. I replaced the disc and that's it.
    If it works, I'll post some more pics. Please help.
  • #2 16550859
    Kasek21
    Help: 4971
    Rate: 3531
    The tape certainly well placed in the nest?
    If so, maybe it's damaged somewhere.
    If not the tape is probably something more serious.
  • #3 16550864
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1538
    Reset CMOS and check if the disk will be visible.
  • #4 16595887
    davede
    It turned out that I had to update the BIOS. Strange, but it worked after that. Thank you all for your help!
