Windows 10 Installer Unresponsive to New HDD on Asus Laptop Despite IDE Bios Setting
adam998 30798 14
How can I make Windows 10 Setup detect the HDD in my ASUS laptop?
Set the SATA controller to AHCI, boot the installer from the USB stick without UEFI (for example with F8), and load the laptop’s AHCI/RAID drivers if needed [#15703840] [#15705570] If the BIOS still does not see the disk at all, the problem is likely not just the installer but the drive or its connection. In the thread, the new disk only started appearing after it was removed and reinserted several times and the BIOS settings were reset, which points to a bad contact/socket issue [#15705676] [#15705735] [#15705767]
  • #1 15703746
    adam998
    Rate: 187
    Windows 10 installer does not see the HDD, the message "load the driver to deliver the storage driver" appears. Old broken disk, the installer sees, I put a new one, does not see ... In the bios set to IDE, the disk connected to the desktop computer is visible working normally ... has any idea install drive in asus laptop.
  • #2 15703787
    Skylakee
    Help: 27
    Rate: 122
    What disk?
    What media are you installing the system from?
  • #3 15703788
    adam998
    Rate: 187
    lokis3 wrote:
    What disk?
    The WD 320GB drive installs the system from a pendrive
  • #4 15703840
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Enter your laptop model. For Windows 10, the disk controller should be set to AHCI if possible. Installation from the USB 2.0 port (if you have USB 2.0 and 3.0 ports in your laptop - try installing from the older generation port).
  • #5 15704147
    adam998
    Rate: 187
    I switched to AHCI and tried through all USB ports and it does not see anything. I recorded Windows 7 on a pendrive and the W7 installer also does not see the disk, although it was switched to AHCI ... I do not know if it mattered?
    The laptop is ASUS Altec Lansing.
  • #6 15704346
    dt1
    Help: 7315
    Rate: 8292
    Read at least the model of this laptop carefully, Altec Lansing produced the speakers for this laptop. You will find the model on the underside of the laptop.
  • #7 15704525
    adam998
    Rate: 187
    Sorry, there is no name anywhere on the housing ... but I entered the bios and wrote K53TK there in the goggles, I checked that there was actually such an Asus K53TK model.
  • #9 15704719
    bamper69
    Rate: 9
    Knowing life, you install in ASUS in UEFI mode :) run instalke without UEFI because then you need to have a disk not on MBR but on GPT and therefore it does not see it.
  • #10 15705514
    adam998
    Rate: 187
    Hello, I checked in the UEFI bios it was enabled, I switched to disabled and it does nothing ....
  • #11 15705570
    bamper69
    Rate: 9
    F8 after boot the computer and choose usb without uefi and install
    And download the ahci / raid drivers to your laptop and upload too
  • #12 15705662
    adam998
    Rate: 187
    I did as my friend ordered, but still the same ... I discovered, however, that in the bios you can not see this disk when I put in the old broken one, does the bios see it but does not see it?
  • Test HDD detection in BIOS and another computer
    #13 15705676
    bamper69
    Rate: 9
    You can not see the disk in the bios at all? Well, in this case it may be a damaged disk, do you have the option of connecting the disk to a stationary? if you had checked it, we would have known immediately.
    Could you please enter what drive it is?
    I was convinced that in bios he can see the disk, but not during installation (then the problem is usually due to the lack of uploaded drivers, e.g. the disk is 2-3TB or using the uefi mode).
    And now like this:
    A) I see a new one, so if the guarantee is then send
    1) If the disk cannot be seen and you want to repair it, first use the disk terminal
    https://www.elektroda.pl/rtvforum/topic872300.html
    2) If this fails, all that remains is to buy electronics and replace the data to copy the data (if you have any)
    3) if you did not have any important documents on it, it remains to buy a new disk and treat it with some achtung ;)
  • #14 15705735
    adam998
    Rate: 187
    So after inserting the old disk to check if the bios can see it, it happened that when I inserted the new disk, the disk "found" strange maybe the socket is not in contact with something but I put it in and pulled it out probably 10 times ..... but also restored the settings factory bios maybe it helped ...
  • #15 15705767
    bamper69
    Rate: 9
    Oh and great. Now set the AHCI mode in your region and install the system as I wrote above (F8, without uefi)
The discussion revolves around an issue where the Windows 10 installer fails to recognize a new HDD in an Asus laptop, despite the BIOS being set to IDE mode. The user reports that the installer prompts for a storage driver, while an old, broken disk is recognized. Various suggestions are made, including switching the disk controller to AHCI mode, using different USB ports for installation, and ensuring the disk is functional. The user identifies their laptop model as Asus K53TK and mentions that the BIOS does not recognize the new disk, leading to further troubleshooting steps, such as checking connections and restoring BIOS settings. Ultimately, the community advises on ensuring proper installation settings and driver availability.
