Audi A3, VW: Repairing Yaw Rate Sensor G202 - Soldering Guidelines & Part Number 1J0907657B
Jap 64278 24
How can I repair the Audi/VW G202 yaw rate sensor and do I need an exact matching donor part number?
Re-solder the sensor’s surface-mount joints rather than just heating it, and if the fault is inside the sensing element, replace the unit with a working used or new one [#16588889] [#16589677] The board in this sensor contains several SMD parts (2×8-pin, 1×24-pin, 2×28-pin ICs plus passives), and the thread suggests cold joints and even vias can fail because the whole plate is suspended on elastics/silicone and vibrates [#16588889] [#21695969] The thin aluminum wires are intentional, so making them stiffer with copper is discouraged because it can affect the suspended structure [#16586117] One user reported that re-soldering the old unit did not help and ended up buying a second-hand sensor instead [#21625619] The thread does not give a definitive rule on exact donor part-number matching, only that a compatible working replacement is the safer route [#16589677]
  • #1 16553604
    Jap
    Help: 114
    Rate: 654
    Hey
    Recently I have damaged the yaw sensor g202 in the Audi A3 - the error was described as impusable signal.
    I read a little on the Internet that these sensors have a weakness in the form of weak solders. What could have been warmed up again - but it seems to me that in 2002 hard automotive February was already used - although from what I remember the ROHS directive came in about 2005/6.
    Auction portals offer ads for repairing the sensor - I suppose it is a porridge with milk - just can anyone share what needs to be done / replaced / can I sell everything by some solder paste? On the English forum I found a description that you should solder out and re-solder the 8 pin chip. There are 2 such chips - but why not just warm it up?
    Plan B
    Does buying a sensor from disassembly have his Part number identical? I found 2 pieces on the back but the numbers were slightly different. For me it is 1J0907657B
  • #2 16558874
    Jap
    Help: 114
    Rate: 654
    Grandfather is terribly expensive - no one will help?
  • #3 16559387
    damdam
    Help: 274
    Rate: 950
    Nitro dissolve this mass, ditch, unbone the pins of the socket, and then when you break off the plate it will turn out that this integrated sensor is soldered. you sold it back and played. chance of success 25%.
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #4 16562009
    Jap
    Help: 114
    Rate: 654
    damdam, it seems to me that you had another sensor in mind.
    My looks in the middle like this:
    Audi A3, VW: Repairing Yaw Rate Sensor G202 - Soldering Guidelines & Part Number 1J0907657BIMG_201706...155233.jpg (3.67 MB)You must be logged in to download this attachment.
    This tile is held by rubber bands. Can there still be a scalpel underneath which you need to sell off?
  • #5 16562349
    mercedesik
    Help: 80
    Rate: 522
    Do not you have these alu wire braids? - most often it breaks.
  • #6 16563742
    Jap
    Help: 114
    Rate: 654
    I moved them lightly - they are all ...
  • Questioning copper wire replacement for sensor bond wires
    #7 16585911
    thimo
    Rate: 14
    Colleagues, I also have a problem with this sensor - the designation 1J0907637B (there is still the second sticker 1J1907637B on it). Do these alu-wires have to be so thin? If I soldered a copper cable there, it would be more reliable, I just do not know what about the vibrations (so that the sensors will not go crazy). What does the tile look like from the other side - did anyone see? I would not like to pick those glued gums - if it turned out that there is nothing to look at ...
  • Thin wires needed to avoid stiffening the sensor mount
    #8 16586117
    Jap
    Help: 114
    Rate: 654
    people who know how to fix it do not want to share because it's a piece of a good penny. I managed to buy the second one ... luckily, the guy did not know what he was selling and it went at an incredibly low price. I recommend going for a shred with an item in your hand and look for such a "relay".
    I asked in a nearby Czech store - price per PLN - 2550PLN.
    As for the wires - they have to be so thin because the whole plate is hanging on elastics - the wires can not stiffen the structure.
  • #9 16588344
    Ireneo
    Help: 747
    Rate: 2472
    I say yes, you have to feel it to assess whether it is a wire, soldering requires practice, here we do not share knowledge because the group szmelcvagen is described only practice is needed ...
  • #10 16588364
    thimo
    Rate: 14
    In that case, if "szmelvagen group is described", please indicate where you can find information on the structure of this sensor (DTR or schematic)?
    A friend, perhaps, only fueled his hostility towards the VAG group's car users (and perhaps he has built up his ego)? I am asking for particulars, not a blank translation, that "you have to feel it"!
  • #11 16588586
    Ireneo
    Help: 747
    Rate: 2472
    I've got a trash myself and found a description on the web, now I associate it next to the sensor. Nothing wires need to be gently from side to side and I used to go one more than others. He did not break it out. He helped me. Thanks to the practice of soldering, unfortunately.
  • #12 16588600
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    If so, let it be a trivial matter.
    Show off whether it worked.
  • #13 16588889
    thimo
    Rate: 14
    A colleague of Jap was more concerned with the description of the repair of the G200 lateral acceleration sensor. There is an 8-pin long-drawn chip and they often leave February - the "advantages" of unleaded tin ..
    In the described sensor G202 Yaw Rate Sensor are scalpers (2 pcs 8-pin, 1 piece 24-pin, 2 pcs 28-pin, 3 pcs transistors and passive elements) and are surface soldered. In my opinion, due to the suspension of the whole plate absorbed by the silicone suspension, cold solders from vibrations should be expected here.
    I removed the plate from the casing, disassembled the screen, if it interests someone - I can send photos.
    I wonder only if the computer reports a fault related to the errors from this sensor (G202), does it not affect, for example, incorrect signaling from the steering angle sensor? Does anyone know what symbol has the sensor at the steering wheel and does it communicate directly with the computer on its own "behalf"?
  • #14 16589677
    masay1
    Help: 40
    Rate: 81
    when it comes to the steering angle sensor, he is in the so-called sliding ring "retractor" under the steering wheel ...
    There are several types depending on the equipment eg tiptronic, mulifunction ...
    nevertheless, let's call it the usual version from ABS and ESP are: 1J0959654AG
    which in turn was replaced by the Newer in 06.2012. at: 1J0959654BK
    as to the transmission of signals it depends again on the equipment,
    because if you have a multifunction steering wheel driver, the signals pass through him ...
    It's not that I want to get rid of but such a "burial" in active systems and this yet
    from the control of the security system which is ABS, ESP; is Very Dangerous ...
    even if you manage to "somehow" fix it, what is your confidence that this sensor will work correcting? ..
    if the ESP security system will receive signals that are correct on the electrical side
    but they have nothing to do with the actual state, and such can send the sensor being repaired is probably
    Nothing more needs to be written ... at a higher speed, not much can be done if the ESP will correct something
    which has nothing to do with the actual situation on the road ...
    if right after turning the ignition switch this error appears, the fault is electric strikte ... eg "cold" solder
    or what happens very often; damaged electrical installation ...
    but if the system recognizes a mistake only after defeating a distance, it may indicate an internal error
    damage to this sensor ...
    anyway...
    if you are sure that the fault lies on the sensor side (not the installation)
    the only sensible solution is to buy a new or functional stimulant ...
    so much my advice ... of course you will do as you please ...
    nice...
  • #15 16589848
    thimo
    Rate: 14
    As for the active security system, I agree, you should not dig too much. My observations concern the situation where during normal driving (especially when starting from a petrol station, or normally on the road on a straight road), the brake of one wheel begins to grind and the car not only loses speed, it is a real chance of an unexpected change of direction This is an unreasonable operation of the ESP system and is confirmed by an error read by VAG (01542 - Angular acceleration sensor (G202)).
    A few years ago I also had a problem with ESP, but then I got the wrong signals from the G200 lateral acceleration sensor and coped with it by blasting the sensor with old tin (with lead) - a method commonly adopted as effective.
    Therefore, I hoped that this time the "damage" of the sensor consists either in the loss of any of the solder connections in the sensor or incorrect indication of the element that works with the sensor, eg the steering angle sensor (although this supposedly has its symbol - probably G85 and in total he should report directly to the computer if he was down ..).
    At the moment I am on the stage of making connections on the smt sensor G202 and after Sunday I will try to test it, did anything help (because it probably will not hurt and it is not an intervention in the active security system, let's call it a factory condition).
  • #16 16636306
    dyjo25
    Hello! I have a similar problem with error 01542. Kolego Thimo helped bailing ??
  • #17 16636707
    thimo
    Rate: 14
    Sorry but no.. :( The problem lies somewhere in the "right" element of the sensor that carries angular acceleration by nature. I bet that this metal "capsule", which you can see when you open the lid (the picture somewhere fade, I'll look again).
    For the curious, I am sending you a plate in the back (the side that you can not see after opening the sensor's lid).
    With screen: Audi A3, VW: Repairing Yaw Rate Sensor G202 - Soldering Guidelines & Part Number 1J0907657B
    without screen: Audi A3, VW: Repairing Yaw Rate Sensor G202 - Soldering Guidelines & Part Number 1J0907657B
  • #18 16762380
    zaxdamian
    Help: 14
    Rate: 67
    thimo wrote:
    Does it not affect, for example, incorrect signaling from the steering angle sensor? Does anyone know what symbol has the sensor at the steering wheel and does it communicate directly with the computer on its own "behalf"?
    Has a separate group in measuring blocks. I exclude an associated error
  • #19 17252365
    Bartex4
    Rate: 21
    and what did the subject matter solve? where is the problem?
  • #20 17277657
    zaxdamian
    Help: 14
    Rate: 67
    After the last batching, he does not throw an error, but he activates with light arcs. I will try again ;)
  • #21 21613783
    bogdanwp
    Dear Sirs,
    I am interested in this topic. Can you please give me some bearings for such a repair?
  • #22 21625619
    zaxdamian
    Help: 14
    Rate: 67
    I bought a second-hand one. Re-soldering the old one did not help
  • #23 21695886
    luckyvannoy
    >>16562009 did you ever replace the burnt diode ?
  • Most G202 sensors can be repaired by soldering
    #24 21695969
    Aleksander_01
    Help: 1167
    Rate: 3435
    There they let the vias go, if someone hasn't done this and is soldering with a transformer then all the best.
    Most can be repaired.
    Added after 26 [minutes]:
    Jap wrote:
    people with the knowledge of how to fix it don't want to share because it's a pretty penny.
    Man stop it, I'd get coffee from laughing. New ones are PLN2300 each but used ones start at PLN100 and I once managed to buy one for PLN20. Indeed, repairing it is a pretty penny.
  • #25 21697868
    Ireneo
    Help: 747
    Rate: 2472
    >>21695969 .
    I even solder processors with a transformer and it's no trouble 😉
The discussion concerns repairing the Audi A3/VW yaw rate sensor G202 (fault 01542 / implausible signal) and whether the failure is caused by cold solder joints or damaged internal components. Participants describe the sensor as a surface-mounted PCB suspended on elastics/silicone, with very thin aluminum bond wires and multiple ICs, making simple reheating unreliable. Suggested repair approaches include carefully opening the housing, inspecting/reflowing or resoldering SMD joints, and checking for broken bond wires or a damaged internal capsule; some report success only after practice, while others say re-soldering did not help and replacement with a used sensor was easier. The thread also compares part numbers and notes that similar sensors may have slightly different stickers/identifiers, while steering angle sensor issues are discussed as a separate system.
