[Solved] VW Vag Błąd 01542-Yaw Rate Sensor (G202)57-00-Electric Circuit Failure
Vtommy 33990 2
  • #1 17934407
    Vtommy
    Hello. Please help me read the error.
    zwirek1
    Level 30  
    Help: 161
    Rate: 308
    Search under the steering wheel, with a bit of luck you'll be able to "resuscitate" him
  • #3 17937272
    Vtommy
    If anyone was looking.
    VW Vag Błąd 01542-Yaw Rate Sensor (G202)57-00-Electric Circuit Failure VW Vag Błąd 01542-Yaw Rate Sensor (G202)57-00-Electric Circuit Failure
