Leaking Samsung Air Conditioner: Causes, Overflowing Bucket, Outdoor/Indoor Unit Distance
berez 11406 11
Why is my Samsung air conditioner intermittently leaking water indoors, and is the condensate bucket/overflow likely the cause?
No, this is not normal; the most likely problem is a faulty or badly executed condensate drain installation, not the fact that the bucket is full. The installer should check whether the condensate pump works properly or whether the drain relies on gravity and has an insufficient slope, because a bad slope can make condensate run back or drain too slowly [#16557669] Another likely cause is a double siphon in the condensate line, especially if the drain is routed through a flexible tube with too small a fall [#16599126] You should also have the drain tube cleaned and blown through, and check the filters and evaporator for frost, since clogging or icing can reduce drainage [#16557682] One reply also points to bad insulation of the pipes under the unit or a badly made drain as the installation fault to complain about [#16558967]
  • Overflowing condensate bucket likely causing leaks
    #1 16557524
    berez
    air conditioning leaks from the news in places marked in the photo.
    Air conditioning is leaking sporadically, but when it "unseals", the effect is as if someone spilled 0.5l of water on the floor: /
    I called the plumbing company, but they told me that "if the water bucket is full, this is normal".
    In fact, the air conditioning had melted four times so far, and the bucket on the balcony was always full at that moment. I take care to empty the bucket, but in hot weather it is easy to overlook this fact (it fills up quickly with 5 liters). And now I do not know if the air conditioning is leaking due to intense work due to the heat or from an overfilled bucket.
    The distance of the outdoor unit to the indoor unit is 1m (one wall).
    My questions:
    Is this a normal phenomenon? (somehow I don't feel like believing)
    What arguments should be presented to the installers for the next complaint?
  • Condensate pump may be undersized or absent
    #2 16557669
    SIEKIERA_666
    Help: 22
    Rate: 79
    Need a more efficient condensate pump - the current one does not work.
    If it was like that from the beginning, it means that they screwed something up at the beginning.
    The bucket has nothing to do with the wet wall, you could have a pool at the end, and if you had condensate dripping down the drain somewhere, you wouldn't even know you're sweating more. If it is warmer muggy stuffy (if you prefer) it condenses more and if the pump would keep up, you would have no problem with the wall but still with the bucket ;)
    Or maybe there is no pump there, only gravity is supposed to work and with a badly leveled tube, there is more condensate in hot weather and it goes back ...
  • #3 16557682
    jack63
    Help: 851
    Rate: 2828
    After all, he wrote that he had a bucket ...
    Berez, take the tube out of the bucket, I assume it is flexible, clean its end and blow it solidly.
    That's the only thing you can do.
    Also spray the filters and clean them with water. By the way, see if the lamellas are not covered with frost in the third fan speed.
    This, in fact, may indicate that the factor is small.
  • #4 16557727
    SIEKIERA_666
    Help: 22
    Rate: 79
    I know...
    I asked nowhere about it.
    p.obelix
    Refrigeration equipment specialist
    Help: 215
    Rate: 563
    Either you have a botched job and someone insulated the pipes under the A / C badly or did the drain badly. Or put in a bigger bucket.
  • #6 16599126
    piotr1paluch
    The cause may be a double siphon in the condensate drain, then the water will not force the air out of one siphon. This usually happens when the drain is routed through a flexible tube and the slope is too small.
  • #7 18866033
    Jakub8401
    buddy from this samsung air conditioning, you dealt with this problem of air-conditioning leak, what photo did you say? I have the same problem and I also have this climate. What the cause? Where to look for the problem and how to solve it?
    My questions:
  • #8 18872180
    wnoto
    Help: 58
    Rate: 745
    how long have you had this air conditioning?
  • #9 18872195
    Jakub8401
    A year but now I have only just started to use so hard before briefly and sporadically
  • #10 18872250
    wnoto
    Help: 58
    Rate: 745
    I am asking because the installations may have been kicked off. Who made it? How is the condensate drained?
  • #11 18872295
    Jakub8401
    A plumber who claims that he did the right thing and is jammed somewhere like I'm waiting for him. Condensation drains too slowly. I live at home. He goes outside. And where was the problem with you? How did you repair? Me overflowing from the tray.
  • #12 18872328
    wnoto
    Help: 58
    Rate: 745
    plumber :) a capable beast of him :)
    Is something really dripping from this tube? Have you watched
    Which means from the tray - for me, the tray is installed on the outside of the air conditioning.
The discussion revolves around a Samsung air conditioner that is leaking water, with the user experiencing significant overflow from the condensate bucket. The user is uncertain whether the leaks are due to the bucket filling up quickly in hot weather or a malfunction. Responses suggest potential causes including an inefficient condensate pump, improper installation, or issues with the condensate drain, such as a double siphon effect. Recommendations include checking and cleaning the drain tube, ensuring proper installation, and possibly upgrading to a larger bucket. The distance between the indoor and outdoor units is noted as 1 meter, which may also affect drainage efficiency.
