Water Temperature Issue in DAF XF 105 460 (2010): Thermostat Replacement, Coolers & Pump Strainer
wega-trans 10848 11
Why does the coolant temperature in a 2010 DAF XF 105 460 rise to about 2/3 of the gauge even after replacing the thermostat and cleaning the coolers?
Check the cooling package thoroughly by removing the radiator/intercooler/liquid cooler and washing each element separately, because blowing them out in place is often not enough [#16559723][#18505026] Verify the actual temperature with DAVIE, test the visco fan, and make sure the correct thermostat is fitted for a retarder-equipped truck [#16565002] There may also be a strainer on the left side of the block under a hex plug that can get dirty and reduce pump efficiency, so it is worth inspecting if your engine has it [#18494293][#16565002] If all of that is OK, a clogged radiator is still a known DAF cause of this symptom and may need replacement [#18509111]
  • Possible clogged pump strainer causing high coolant temperature
    #1 16557839
    wega-trans
    Rate: 12
    HELLO
    I have a problem with the daf xf 105 460 from 2010, I replaced the thermostat, I blown the coolers and the car still catches the water temperature, which reaches 2/3 of the clock, no messages are lit, the fan starts as the pointer is approaching 2/3 of the clock, a moment comes and the situation is quiet it is both on an empty and a loaded car, the last one at a temperature of 32 degrees Celsius, the water rose even when driving empty on a fairly level ground, after consulting the service, the guest said that in my model there is a strainer under the plug on the pump and it can be clogged and reduces the pump efficiency water, however, on any forum no one raised such a topic and invisible whether to disassemble it if it has no effect on temperature fluctuations, the liquid after draining cleanly, like a new zero coffee grounds or dirt, and my question sounds because in other forums the guest Kris claims that it is normal engine operation, however in other dafas that I have ridden, I have no place for tips, it starts but not so fast and not at every hill or light engine loads
    a car with a retarder, I would ask the guests for a reply about niku kris brum or something like that because after analyzing several forums, I can see that the guest has quite good knowledge about dafa
  • #2 16559548
    darfur5
    Help: 267
    Rate: 1715
    Maybe the coolant pump has become inefficient? This is my first thought. Blowing out the radiator kit is quite difficult if you have air conditioning, an intercooler and a liquid cooler. Maybe KRIS has a vacation and is now on a Hawaiian beach, but it's worth waiting for his opinion because he knows DAF like few people.
  • #3 16559723
    kisiol
    Help: 36
    Rate: 469
    If you didn't remove the intercoler and cooler outside. It's like you don't clean it. You have to remove it from the car and separate, wash each element separately. It seems obvious.
  • Suggesting DAVIE diagnostics and thermostat checks
    #4 16565002
    bubus16oppl
    Rate: 11
    I propose to connect DAVIE to know what value we are talking about. 2/3 clock is not very detailed ...? What temperature sensor. Original or replacement? .. Does the car burn more? Monitor pressure at the EST 52 the lower coil to be checked. Visco test done on the site? If there is a retarder, has a good thermostat been inserted? Retarder cars have different thermostats.
    Regarding the strainer, I doubt that it was there ... I have not seen this strainer for a long time and with such a problem I check it ... Secondly, at high temperature (2/3 clock) the viscosity of the oil would drop and you would have a blade. engine for orange ...
  • #5 16569492
    hubert04
    Help: 60
    Rate: 408
    is there a noticeable drop in power when the temperature is raised?
  • #6 16571383
    Heroses
    Help: 71
    Rate: 160
    One thing is good flushing the radiator. The question is whether the temp goes up on the flat too. ??
    For the sake of peace of mind, check the retarder coils for seized
  • #7 17335942
    Diodo0
    Hello. I have the same problem, have you solved the same problem at home?
  • #8 18494293
    wega-trans
    Rate: 12
    It is not still the same, but I think this type has so I checked everything the only thing left is a liquid cooler for the interested DAF has a strainer on the left side of the block that also likes to get dirty under the hex plug.
  • #9 18502137
    Trucker Daf
    Help: 8
    Rate: 59
    If the reason for heating is the accumulation of compression in the cooling system (you can hear gurgling in the cabin heater then), the reason lies in the collapsed sleeves, which causes air to the system. cooling.
  • #10 18505026
    hubert04
    Help: 60
    Rate: 408
    1 strainer in the oil module is not present this year, and if it was already in the first inspection, it was removed. 2 check the thermostat housing likes to be wiped out and the liquid is chasing in it 3 the cooler to take out and clean it well with an intrcooler and this should do the trick regarding heating
    I know that you bought yourself from before for milling, but you do not need to advertise regularly These types of problems do not only occur in Dafa but also in Man and SCANIA
  • #11 18505536
    Trucker Daf
    Help: 8
    Rate: 59
    Yeah, Mana and Scanie, I've got it worked out too :)
  • #12 18509111
    ivan111
    Help: 7
    Rate: 41
    Normal thing in Dafa. Clogged radiator. Replace with a new one and forget about the problem.
The discussion revolves around a water temperature issue in a DAF XF 105 460 (2010) model, where the temperature gauge reaches 2/3 without triggering warning lights. The user has replaced the thermostat and cleaned the coolers but continues to experience overheating, even under light loads. Suggestions include checking the efficiency of the coolant pump, ensuring thorough cleaning of the intercooler and radiator, and investigating potential air accumulation in the cooling system. Some participants mention a strainer in the cooling system that could be clogged, while others suggest that the problem may be common in DAF vehicles, recommending a radiator replacement as a potential solution.
