Renault scenic 1.9 dci - Candle light burning, lack of power, mostly uphill
patron116 10152 5
  • #1 16559161
    patron116
    Hello, I have Renault scenic 1.9 dci 2002 for some time now the glow plug indicator starts lighting up but only uphill. I replaced the turbine pressure valve EGR was cleaned about 8,000 thousand km and oil changed 9,000,000 km ago. I will add that when I push the gas to the top, a bit of black smoke comes out of the pipe and when I'm at a standstill, it often waves with a turnover between 600 and 1000 revolutions. Is the turbine ending its life I have 203 thousand miles.
  • #2 16559212
    panstalin2
    Help: 30
    Rate: 216
    It looks like the injection is pouring.
  • #3 16559341
    piwko
    Help: 87
    Rate: 213
    patron116 wrote:
    egr was cleaned about 8,000 thousand km and oil was changed 9,000 thousand km ago
    Egr, did you clean 8 million kilometers ago? There is no oil that can withstand 9 million kilometers. The abbreviation of thousand is thousand
  • #4 16559372
    patron116
    sorry for the mistake with these thousands, I wanted to add some 1.2 l of oil.
  • #5 16559607
    paul7
    Rate: 25
    check egr and westgate to control the turbine
  • #6 16562524
    sebap
    Help: 538
    Rate: 1082
    Remove the EGR, clean, install and do not connect the plug.
