Renault Scenic 1.9 dCi 2001: Error DF198, Displacement Sensor Circuit, Glow Plug Light On
arrrturek 16995 5
  • #1 16659540
    arrrturek
    Rate: 67
    Hello, I need help. The computer crashes the error df 198 the displacement sensor circuit No. 2 of the current. The glow plug indicator light is on. One potentiometer and the one under the hood. What could be the reason?
  • #2 16659782
    kamiloskop
    Help: 42
    Rate: 278
    Connect the clip ...?
  • #3 16669125
    arrrturek
    Rate: 67
    Sory that he writes back so late but I couldn't earlier, buddy what did you mean with the clip?
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    According to the error you wrote it to replace the gas pedal.
  • #5 16669197
    arrrturek
    Rate: 67
    ok I will try to replace the gas pedal again, let me know what and how
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    Sorry, I did not read that you have already changed the bundle, it is best to check in live data if you can see 2 potentiometer channels.
    It may also be that you are reading it with a bad clone of Chinese and the real error is different, so your friend suggested you a Renault can clip to be sure that you have the right error.
