Mercedes W205 2015: Collision Prevention Assist Plus Inoperative, Error B220600
helmut34 30906 12
What does Mercedes fault code B220600 mean and how do I fix Collision Prevention Assist Plus inoperative on a 2015 W205?
B220600 means the vehicle ID number is incorrect or not present, so the radar/collision module needs to be coded to the car’s VIN rather than simply replaced [#15358429] The forum advice is that the module itself is probably fine, but it is not yet properly added/adapted to the vehicle, so you will likely need SCN coding, reset learned values, clear fault codes, and retest the car [#15358429][#15359518] A used module will still give the same issue if it is not signed to the VIN, and even a new one may not work just by plugging it in [#15362630][#15364495] Several replies say this is not something you can realistically solve on your own without the proper diagnostic equipment and coding access, so diagnosis first, then repair [#15364495][#15362630]
  • #1 15357829
    helmut34
    Rate: 22
    Hello, I am the owner of a Mercedes W205 from 2015. The message Collision Prevention Assist plus inoperative is displayed. I bought a car with minor damage. I have already replaced the radar sensor in the car and the wiring in the bumper, which was damaged. It did not help, the message is still displayed. I was there. at two mechanics, they detected the error -B220600, but neither of them can find a description of this error and remove it. I called the Mercedes showroom and they told me a very high price for the repair, because the car is not covered by warranty. Does anyone of you have an idea what is wrong? yes? Or what does this error code mean? Thank you very much for any help. Regards.
  • #2 15358429
    karas44
    Help: 12
    Rate: 65
    http://mbworld.org/forums/c-class-w205/598622-collision-assist-inoperative.html
    A little hint and code :)
    B220600 - CURRENT VEHICLE ID NUMBER IS INCORRECT OR NOT PRESENT
    CARRIED OUT SCN CODING OF MODULE, RESET LEARNED VALUES OF MODULE
    CLEARED FAULT CODES AND RETESTED VEHICLE
    MB service told you well, I`m a huge fan of the brand and I wish you many kilometers, but MB failed with this one
  • #3 15359396
    helmut34
    Rate: 22
    Thanks for the answer, but I don`t really understand, does it mean that I bought the wrong sensor? Please answer. Thank you
  • #4 15359518
    Pawel wawa
    Help: 1262
    Rate: 4433
    You bought a good module, but now you have a problem with adding it to the car. In short, you won`t be able to figure it out on your own.
  • #5 15359547
    helmut34
    Rate: 22
    I understand that it has to be done with a computer? I just don`t understand why the service wants PLN400 from me just to remove the bumper.
  • #6 15359594
    andrzej20001
    Help: 1578
    Rate: 6669
    Because you have such a Merc and you can obviously afford 400E for the repair.
  • #7 15362415
    helmut34
    Rate: 22
    Hello, is it possible that I bought a module from a damaged car and it has a collision saved, so it doesn`t want to connect to my car? If I buy a new module now, will it connect without any problems? I am asking for help and advice.
  • #8 15362630
    karas44
    Help: 12
    Rate: 65
    It`s not like that. your module is ok, the problem is that it has a collision error saved and it is not compatible with the vin number. it`s a fairly new car and no one except Mercedes will be able to fix it for you and make sure it`s OK
    It`s a bit like trying to change the ignition without a key.
  • #9 15362706
    Pawel wawa
    Help: 1262
    Rate: 4433
    karas44 wrote:
    no one except Mercedes will sort it out for you and make sure it`s OK
    He`ll get it, he`ll get it. Such things are already being done.
  • #10 15363587
    helmut34
    Rate: 22
    And if I buy a new module, will it work and will it connect to the car?
  • #11 15363826
    karas44
    Help: 12
    Rate: 65
    You probably don`t understand anything, a new module (org clean Mercedes) that will be signed to your car will cost more this module than this repair, but just connecting a new one will not mean that the ECU will accept this module so beautifully without erasing the errors, and the used one new one, the same error will occur.
  • #12 15364495
    Pawel wawa
    Help: 1262
    Rate: 4433
    No one will give you a guarantee without seeing the car. Don`t expect hasty opinions. The answer is, diagnosis first, statement later. Either way, just "plugging in" probably won`t work.
  • #13 15419043
    helmut34
    Rate: 22
    Hello, I have a question for PAEWL wawa. Do you know which workshop would handle this for me? Please give me the directions.
    Added after 1 [minute]:
    Maybe other users know where I can do such things? The best place would be in the Świętokrzyskie Voivodeship.
The discussion revolves around a 2015 Mercedes W205 experiencing a "Collision Prevention Assist Plus inoperative" error, specifically error code B220600. The owner has replaced the radar sensor and repaired the bumper wiring, but the error persists. Responses indicate that the error may be due to an incorrect or missing vehicle identification number (VIN) in the module, which could be a result of the module being sourced from a damaged vehicle. It is suggested that only authorized Mercedes service can properly diagnose and reset the module, as simply replacing it may not resolve the issue without erasing previous collision data. The high repair costs quoted by the dealership are also a point of concern for the owner.
