Alternative to Somfy Centralis Uno controllers operating with the Tahoma control unit
michu82 2970 0
  • #1 16559899
    michu82
    I have 14 roller shutters in my house with Simu Job 5S motors (wired with regular switches).
    In the meantime I have installed a gateway with a Somfy operator and had a choice of a Conexant to control this gateway or a Tahoma.
    I took the Tahoma because of the possibility of possible expansion.
    And now the question: I want to connect these 14 roller shutters to the Tahoma. Is the only working option to replace the current switches with Somfy Centralis Uno
    or are there any other alternative options? I ask because the Tahoma has support for several protocols and it doesn't have to be RTS or IO.
