Integration of conventional roller shutters with Velux io-homecontrol - how?
bumek123 2841 5
  • #1 17641718
    bumek123
    Hello, I have a question regarding roller shutter control. I have two Velux roof windows with SML 0000s roller shutters powered by a KUX 110 wireless controller and operated by a KLR100 remote control (io-homecontrol). I would like to incorporate into this system three external roller shutters whose controllers I do not yet have. This is a normal roller shutter powered by a four-wire cable. Am I able to integrate this into one system without spending a lot of money and control everything with the KLR100 remote control?
  • #2 17641819
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1011
    Don't you think such a question is best asked of Velux?
  • #3 17642278
    bumek123
    Well, I don't think so, because they'll just push in equipment for a billion zlotys.
  • #4 17648057
    Level 37  
    Help: 211
    Rate: 1011
    Forgive me if the question is too personal but: then why do you buy windows from a company you consider to be dishonest?
  • #5 17649013
    bumek123
    And who said I thought they were dishonest?
  • #6 17649481
    Marek J.
    Help: 526
    Rate: 950
    You will probably find something by looking for compatible io-homecontrol products at least at Somfy.
    These can be 868 MHz radio receivers mounted in the roller shutter or in the box under the switch.
    However, don't count on this being 100% interoperable. Motors for io-homecontrol roller shutters (e.g. Somfy Oximo) have two-way communication and will inform you of the position of the roller shutter, for example. In the case of normal asynchronous motors for roller shutters, there is no such information....
    Call/ write to Somfy and ask if they have controllers that support io...... in the form of modules for normal 230V roller shutter motors.
