Beko WMD 77125 -How to reset the washing machine error error E10
adrian358 12519 8
  • #1 16403352
    adrian358
    I have a problem with the washing machine. After entering the service mode, it shows error E10 - door failure. The cause has been removed, but I cannot clear this error.
    Please help.
    Adrian
    TONI_2003
    Moderator
    Help: 2194
    Rate: 3821
    adrian358 wrote:
    The cause has been removed but I cannot clear this error.
    Yes, what about the results?
  • #3 16491937
    adrian358
    What type of SMD resistors is this?
    Triac and R53 resistor fell, values 1k.
  • #4 17640522
    rapbalance
    Rate: 21
    I have a similar problem, but I also can't delete the E10 error, even holding Start. Of course, cause and effect as in the picture eliminated. So is there another way to reset the washing machine? Or maybe something else on the module could have fallen - could a micro processor?
  • #5 17640943
    UczenEl
    Help: 31
    Rate: 390
    And there by accident, apart from start / pause, you do not need to press any button yet?
  • #6 17641112
    Piotr2608
    Help: 851
    Rate: 4486
    You don't have to, the module is badly repaired (something is still damaged) - the cause is not there
    eliminated.
    ZimTech Piotr Zimny
  • #7 17641748
    rapbalance
    Rate: 21
    Piotr2608 wrote:
    the module is badly repaired (something is still damaged) - the cause has not been eliminated.
    I will add that the display is backlit, but it does not respond to any buttons (Start, Temperature, Centrifuge etc) but only to the program change knob. Is this already a sign of processor damage or some components?
  • #8 17642054
    Piotr2608
    Help: 851
    Rate: 4486
    It is possible that triac drivers should be checked.
    ZimTech Piotr Zimny
  • #9 17731182
    rapbalance
    Rate: 21
    I checked HCF4069U and it's ok, so it seems to damage uK?
✨ The discussion revolves around the Beko WMD 77125 washing machine, specifically addressing the persistent E10 error indicating a door failure. The original poster, Adrian, has resolved the initial cause of the error but is unable to clear it. Various responses suggest potential issues with the washing machine's control module, including possible damage to the microprocessor or triac drivers. Some users inquire about the need for additional button presses to reset the error, while others speculate on the condition of specific components, such as SMD resistors and the HCF4069U chip. The consensus indicates that the module may still be malfunctioning despite the apparent resolution of the door issue.
