Sharp Aquos 32CHE5100E: Exiting Service Mode with Remote Control (K, W, & 0 Displayed)
Gregor115 11601 2
  • #1 16564793
    Gregor115
    Rate: 8
    I have TV Sharp Aquos 32CHE5100E, I accidentally turned on some mode with the remote control and the letter "K" appeared on the screen in the yellow square and under it the letter "W" and "0". How to exit this mode?
  • #2 16564886
    Polon_us
    Help: 1184
    Rate: 1280
    Please see this topic -> link
    Maybe something will be helpful
  • Repeated service-mode exit attempts failed
    #3 16564922
    Gregor115
    Rate: 8
    Tryb serwisowy:
    1- Unplug the AC power cord of TV set to force power off.
    2- While holding down the “VOL (–) ” and “INPUT” keys on the set at once, plug in the AC power cord to turn on the
    set. The letter K appears on the screen. (Factory mode)
    3- Next, hold down the “VOL (—) ” and “P ( V )” keys on the set at once. Multiple lines of orange characters appearing
    on the screen indicate that the set is now in the adjustment process mode. If you fail to enter the adjustment process
    mode (the display is the same as normal start up), retry the procedure.
    4- To exit the adjustment process mode after the adjustment is done, unplug the AC power cord to force off the
    power. (When the power is turned off by the remote controller, unplug also the AC power cord and wait for 10
    seconds before plug it in again.)
    5- To remove “K” mode, just repeat steps 1 and 2. This time the letter K disappears from screen.
    tym sposobem próbowałem ale nic nie daje siedze juz nad tym pare godz i kombinuje właśnie z różnymi kombinacjami klawiszy ale dalej jest to samo...
