- NC + Abroad: Access TVP1, TVP2, TVN, Polsat on Satellite - DVB-T Standards & Decoder Usage
Adoram 13188 9
Can I receive TVP1, TVP2, TVN and Polsat abroad on an NC+ satellite decoder, or does the green terrestrial-broadcast icon mean they are only available via DVB-T?
Yes, those channels are received via satellite; the green icon is only informational and does not mean the NC+ decoder uses DVB-T for them [#16447312] Current NC+ decoders receive only MPEG4 DVB-S2, and all programs marked in the offer are available via satellite [#16452191] So if Hot Bird is within range where you are abroad, these channels should still be available there [#16447312][#16447868]
  • #1 16446854
    Adoram
    A totally newbie question: I am going abroad, but I would like to have a satellite TV in Polish (yes, I know that the rules are forbidden). I am looking at the NC + offer, but I see that TVP1, TVP2, TVN, Polsat and several others are marked in each package with a green icon meaning "Program available via terrestrial broadcasting". Do I understand correctly that it means that the decoder receives them in the DVB-T standard and will not be these channels abroad? Or maybe there is some way of receiving these programs abroad on the NC + decoder?
  • #2 16446999
    telesat1
    Help: 104
    Rate: 258
    Bad reasoning.
    Programs broadcast via SAT.
  • #3 16447166
    Adoram
    OK, but if so, why are they marked with this sign?
    - NC + Abroad: Access TVP1, TVP2, TVN, Polsat on Satellite - DVB-T Standards & Decoder Usage [/ Img]
  • #4 16447182
    telesat1
    Help: 104
    Rate: 258
    Do you have a SAT set?
    What and where?
    Ahead.
    SAT set of paid operator (NC +, Polsat) receives these programs by satellite dog.
    Adoram wrote:
    but I see TVP1, TVP2, TVN, Polsat and several others
  • #5 16447262
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    @ telesat1 The question is still where @Adoram is leaving? If he escapes from Astra or Hot Bird, he will have to combine like me. :cry:
  • #6 16447312
    LeDy
    Help: 1990
    Rate: 2938
    This is only information and has nothing to do with receiving them abroad, within Hotbird's reach.
    Because the operator did.
  • #7 16447797
    Adoram
    I do not have it yet, I'm trying to buy because I wonder if it will be OK.
    telesat1 wrote:
    What and where?
    Such as I inserted above. In the channel list, e.g. here:
    http://ncplus.pl/sklep/oferta/start-premium
    TVP TVN, Polsat etc. programs have such a green designation in the corner, which is explained below as receiving by DVB-T.
    Luckily, HotBird is visible, I checked.
  • #8 16447868
    rosak
    Car dashboards specialist
    Help: 142
    Rate: 559
    As has already been said, the programs you are asking for are available from the satellite abroad.
  • #9 16447889
    sanfran
    Help: 963
    Rate: 3004
    If the friend goes to the UK, after connecting the terrestrial antenna to the decoder, he will have a full FreeView package (Terrestrial Digital TV). The benefit is that you can record if the decoder has HDD.
    3.1.11. Do not send messages that do not contribute to the discussion. They are misleading, they are dangerous or they do not solve the user's problem.
  • #10 16452191
The discussion revolves around accessing Polish satellite TV channels (TVP1, TVP2, TVN, Polsat) while abroad using the NC+ service. Users clarify that despite the channels being marked with a green icon indicating terrestrial broadcasting (DVB-T), they are still available via satellite for subscribers outside Poland. It is noted that the NC+ decoders are compatible with MPEG4 DVB-S2 standards, allowing reception of these channels abroad, particularly through satellites like Hotbird. Users also mention the possibility of using a terrestrial antenna in the UK to access FreeView channels, enhancing the viewing options for Polish expatriates.
