Limiting Dedicated RAM for Intel HD Graphics 5500 on Lenovo B50-80 Laptop
2oneX 10068 4
  • #1 16565608
    2oneX
    I created an account because I can't find the answer to my problem anywhere. Everyone wants to increase the amount of dedicated RAM for the graphics card, but I would like to limit it. The equipment is a Lenovo B50-80 laptop with an integrated card from Intel HD 5500, as standard it had 4GB RAM but I added a bone in dual and now is 8GB, while in some situations I sometimes lack it and as I managed to notice the card reserves half of the RAM that I have, i.e. 4GB what you don't need in the graphics. And hence my question if you can somehow assign a RAM limit for this graphic in Win10, in the BIOS there is no such function I have already checked and Microsoft support does not write anything about it.
  • #2 16565617
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    The memory of the card is set to 128MB as seen on the screen.
  • #3 16565631
    2oneX
    Dedicated yes, but the total is 4GB and in games it also shows that the graph has 4GB of memory.
  • #4 16565726
    Matuzalem
    Help: 1653
    Rate: 1101
    There is no maybe have (if needed). Of these 4 GB, the actual amount is taken and dynamically released. The CPU specifications indicate that 16 GB graphics memory max what about Max Memory Size (dependent on memory type) 16 GB points to just that variable - depending on your needs - how to use shared memory by the graphics system.
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #5 16892648
    2oneX
    I'm still tired but I close.
