Increase Intel HD 4000 VRAM on Windows 7: Boost from 64MB to Higher - Possible Methods?
brojitsu 9024 5
  • #1 16867830
    brojitsu
    Hello. Is it possible to increase the Vram for the Intel HD 4000 card?
    Currently, it is a paltry 64 m.
    System: Windows 7
    RAM: 8 GB
    PS I would like to add that the "IncreaseSegmentSize" type tricks in the registry do not work.
  • #2 16867846
    sewek1000
    Help: 17
    Rate: 26
    You already have the maximum VRam set, the Intel graphics memory is 64 Mb, the rest of the memory is taken from Ram or VRam which you have given as the total available graphics memory - 1696MB.
  • #3 16867852
    brojitsu
    Is it possible to increase the total available graphics memory then?
  • #4 16867866
    sewek1000
    Help: 17
    Rate: 26
    You would have to check if there is an option to increase in the BIOS, I'm not sure if it's the maximum limit or not, maybe adding RAM would help but I'm not sure to wait for someone else to speak.
  • #5 16867888
    Piterixos
    Help: 38
    Rate: 56
    What for? Those over 1.5GB are three times too much for this card.
    The disc probably limits the amount of shared memory, it would be easier to tell if you gave the model ...
  • #6 16867897
    enhanced
    Help: 963
    Rate: 883
    And something is not working that you want to increase?
