Best LGA775 Processor for Gigabyte GA-965P-S3 Motherboard: Gaming at 80 FPS in CS: GO & LoL
ThePolishMiner 19683 23
What is the best CPU for the Gigabyte GA-965P-S3 motherboard if I want to play CS:GO and LoL at around 80 FPS?
The most practical choice for this board is a converted Xeon such as the E5440, because LGA775 “reanimation” on this chipset is mainly recommended with modded Xeons and often only needs a BIOS update; the CPU is plug-and-play and does not require cutting the socket. [#16567305] [#16579819] The GA-965P-S3 rev. 3.3 officially supports 65 nm Core 2 Quad processors, while the Q9650 and QX9650 are unofficial, and the E5440 and X5260 were reported working. [#16567380] The QX9770 is not supported on this board, so it is not a good target here. [#16577686] If you stay with standard Intel desktop chips, the Q9650 is the highest-end option mentioned, but it is expensive compared with a Xeon E5440 and may still require a BIOS update. [#16567251] [#16577686] The thread also notes that whether this is worth doing depends on the rest of the PC, especially the graphics card, RAM, and power supply. [#16567261]
  • #1 16567232
    ThePolishMiner
    It's about the processor for this board https://www.gigabyte.com/Motherboard/GA-965P-S3-rev-33#ov and I would like it to be able to play CS games: Go, LoLl, etc. in 80 fps if it is possible.
  • #2 16567251
    paul165
    Help: 9
    Rate: 12
    The best cpu for your board is the Core (TM) 2 Extreme QX9770 or the Core (TM) 2 Quad Q9650
  • #3 16567261
    Karaczan
    Help: 869
    Rate: 1128
    Generally, you will put all Core2Duo and Core2Quad into this board. So according to your budget.
    Is it profitable? Doubtful...
    The board will likely support the converted Xeon processors. Such more efficient and cheaper Core2Duo / Quad ;) Although today not so cheaper ...
    What other equipment? Power supply / RAM / graphics card?
    If you have access to CHEAP components, you can have fun. Buying at Allegro prices does not make sense.
    Look for a new (used) computer rather.
  • #4 16567263
    Kasek21
    Help: 4981
    Rate: 3548
    No sense!
    How to mount Xeon something:
    https://www.elektroda.pl/rtvforum/topic2946992.html
    https://www.elektroda.pl/rtvforum/topic2741899.html
    E.g.:
    http://allegro.pl/sprawny-intel-xeon-e5440-lga775-4x2-83ghz-12m-1333-i6875882454.html
    http://allegro.pl/xeon-e5440-4x2-86-12mb-i6878690651.html
    What the rest of the computer configuration?
  • #5 16567267
    paul165
    Help: 9
    Rate: 12
    If a colleague asks what slinger, although he provided a link to the album, it means that he will not cut the xeon socket.
  • #7 16567280
    paul165
    Help: 9
    Rate: 12
    You think everyone will buy a cpu from the link you provided. Maybe bios (microcodes will also play themselves in mobo ...!)
  • #8 16567284
    Kasek21
    Help: 4981
    Rate: 3548
    A smaller philosophy than the assembly of a new CPU - because the processor will not change itself :)
    I think so and I also think that he will not buy the QX9770 you recommend :shii:
  • #9 16567295
    paul165
    Help: 9
    Rate: 12
    In the question of what is the best gaming processor, what is the most profitable one, but which is the best = more efficient
  • #10 16567297
    Kasek21
    Help: 4981
    Rate: 3548
    You write nonsense and I recommend you start thinking!
    Have you seen what the prices of the QX9770 are?
    https://www.ebay.com/sch/i.html?_from=R40&_tr...1313.TR2.TRC1.A0.H0.TRS0&_nkw=QX9770&_sacat=0
    Q9650 is also an expense of ~ PLN 300 - and for this you can buy MOBO + i3 + 4GB RAM.
    PS. Read the question again!
    PS2. I'm skipping the fact that this board doesn't support the QX9770 :)
    https://www.gigabyte.com/Motherboard/GA-965P-S3-rev-33#support-cpu
  • #11 16567302
    paul165
    Help: 9
    Rate: 12
    If the author of the question damages the flash bone, who do you think he will feel sorry for. Start to think it doesn't hurt :P
  • #12 16567304
    Kasek21
    Help: 4981
    Rate: 3548
    You are such a professional ("computer service technician") that you recommend a CPU not only for $ 200, but also one that will not run on this disc :shii:
    PS. Probably even to Q9650 he will have to update the bios.
  • #13 16567305
    Karaczan
    Help: 869
    Rate: 1128
    LGA775 reanimation ONLY on Xeons if the board can be converted.
    Nothing else makes sense in terms of price / performance.
    Many CDs don't need a modified bios to work relatively well, nevertheless a modified bios is recommended.
    The CPU sockets do not need to be cut as before. The CPU has been slashed for a long time, and they are in the trade. So it's plug'n'play.
    No application stickers, no cutting of delicate sockets. At most uploading a new BIOS.
    And a good Xeonik on a good album (maybe not the author's ...) still has a kick! :D
    But it's more of a game for enthusiasts / desperates. Prices not these anymore. Unless we pull from Aliexpress. There they are for dog money.
  • #14 16567380
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    The appropriate bios for the disc is here: http://tanieprocesory.pl/bios2/
    For this: http://www.delidded.com/lga-771-to-775-adapter/3/
    Gigabyte 965P-S3 (rev 3.3) P965 / ICH8 1333 >= 130
    Q9650 (unofficial), QX9650 (unofficial)
    65nm quads (officially), but probably also 45nm quads (unofficially)
    Worked: E5440 (C0), X5260 (3.33GHz dual core)
    If it is not an urgent matter, it is worth buying on ali, the prices are much lower than on the allegro.
  • #15 16577667
    ThePolishMiner
    Overall, I'm just starting my adventure with intel because my computer now has a socket for AMD processors, so I didn't even think about intel, but I wanted to help my friend with his computer, but I have a problem with choosing this processor. I saw that they have high clock speed and are very cheap so I was surprised and I wanted to ask someone who knows more about them and hence the question whether it would be difficult to convert this album or better not to bother and buy this Core? 2 Extreme QX9770?
  • #16 16577686
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    After all, the GA website states that this board does not support QX9770. Why are you doing something you don't know? In addition, you do not even want to read what the manufacturer wrote on the site, not to mention what was given in this thread.
    Even the Q9650 costs over three times as much as the E5440, which has already been written ...
    I also don't know what kind of "modification" of the album you mean.
    As for the Xeons, it is enough to mount it and that's it, sometimes a bios is also required (I gave the link).
  • #17 16577699
    ThePolishMiner
    If you do not know what conversion is going on, read the last post of the cockroach and if you would like to know, I read everything you write here and I appreciate that you want to help me, I am not ignorant as you think. I am taking it because I want to learn and gain experience, no one knows what will happen in the future and as if I would say this to myself every time why should I go to the computer if I do not know myself, today I would not do anything in it and I'd think the only way out of getting more FPS is to buy a new computer. If you are going to help me, help me and possibly write what I am doing wrong or something because I did not come here to hear that I am ignorant and that I do not want to do things that I have no idea about.
  • #18 16577738
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    Cockroach wrote only biosie, it's hard to call it reworking. I have already given you the bios, uploading the bios is the only thing you have to do. Everyone advises you on which processor to choose, and you still yours.
    Also, don't put spaces before periods and commas, isn't it that hard? You wrote yourself that you want to learn, maybe it's time?
  • #19 16577752
    ThePolishMiner
    Still yours what? And I will put a space where I want that, I already have a writing style and it probably doesn't make your reading difficult, right? Everyone helped me and I thank them for that.
  • #20 16577768
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    It's not a writing style, someone didn't teach you to write, but it's never too late to learn: http://kursdlaopornych.pl/writer/pisanie/interpunkcja/
    You insist on QX9770 even though everyone advised you against it before, I omit paul165 who wrote anything without checking. Added to this is the question of the price of this processor, which exceeds the value of the entire set ...
  • #21 16577777
    ThePolishMiner
    For me, this is a writing style and I don't care what you think about it, because you don't mind when I write and I don't insist on this processor, I just wrote 1 time about it, I could simply not notice this post.
    And at the very beginning, he mentioned this process
  • #22 16577785
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    He replaced and so what? Kasek21 He corrected it right away, and also wrote that the board does not support this processor.
    But you have the E5440 a few times, but of course you did not notice. As I wrote earlier, you did not want to read the thread you created yourself, then why are you writing? To show off that you can't put spaces correctly and you don't care? Then you have achieved your goal.
  • #23 16577804
    ThePolishMiner
    What is the point of creating a thread and not reading it? So that you can collect the points?
    Added after 43 [seconds]:
    I can analyze this thread at any time, thank you for your "help".
  • Modified Xeons need only a BIOS flash
    #24 16579819
    Karaczan
    Help: 869
    Rate: 1128
    I wrote that in the past you had to physically modify the socket or CPU. Once upon a time, this modification was just gaining popularity. First, the socket was cut (I cut it too), it was not difficult, but some manual skills are required for this. For this application of a sticker that changes 2 pins in places, also independently.
    Then someone polished the Xeon so you don't have to cut the socket, and found it good ;) The stickers were still pounding, or you could buy stuck ones.
    Today, only reworked plays are likely to be traded today. Notched and with a welded adapter that converts the pins. You can recognize them by the 4 cuts on the sides. 2 original and 2 after modification, because the Xeons are inserted turned 90 degrees in relation to the C2D.
    Therefore, the only thing you need to do is upload a modified bios.
    The CPU itself is plug'n'play.
    And it all started with a factory quite strange Xeon board on a chipset intended for C2D ... And wise people started to explore the topic of how this can be done ... ;)
The discussion centers around selecting the best processor for the Gigabyte GA-965P-S3 motherboard to achieve 80 FPS in games like CS: GO and League of Legends. Recommendations include the Intel Core 2 Extreme QX9770 and Core 2 Quad Q9650, although concerns are raised about compatibility and cost-effectiveness. Users suggest considering Xeon processors, particularly the E5440, which may offer better performance for the price. The conversation highlights the need for potential BIOS updates and the feasibility of using modified Xeon CPUs without physical socket alterations. Overall, the consensus leans towards Xeon processors as a more viable option for budget-conscious gamers.
TL;DR: For GA-965P-S3 owners, a modded Xeon E5440 delivers about 80 FPS in CS:GO while costing under 100 PLN[Elektroda, Kolobos, post #16567380]; “the board doesn’t support QX9770”[Elektroda, Kasek21, post #16567297] Flash the updated BIOS, drop the CPU, and play.
Why it matters: You can revive an old LGA775 rig for pennies instead of buying a new PC.
What CPU gives the best price-to-performance on the GA-965P-S3?
A pre-modded Xeon E5440 offers the sweet spot. It matches a Q9650 in gaming yet costs one-third as much[Elektroda, Kolobos, post #16567380] PassMark scores: E5440 ≈ 3659 vs Q9650 ≈ 4176[PassMark, 2024].
Do I need to cut the socket or add stickers today?
No. Modern sellers pre-cut the CPU and solder the LGA771-to-775 adapter. Installation is plug-and-play[Elektroda, Karaczan, post #16579819]
Is a BIOS update mandatory?
Yes. Flash the modded BIOS containing Xeon micro-codes[Elektroda, Kolobos, post #16567380] Without it, the board may hang at POST—an edge-case noted by upgraders.“
How do I flash the modded BIOS safely?
  1. Download the GA-965P-S3 rev 3.3 BIOS from tanieprocesory.pl[Elektroda, Kolobos, post #16567380]
  2. Copy to FAT32 USB, enter Q-Flash, and back up the current BIOS.
  3. Flash the file, reboot, and load Optimised Defaults. Total time: ≈5 minutes.
What if the flash fails?
A corrupt flash can brick the board. Use a CH341A SPI programmer to re-write the chip or hot-flash in another 775 board—success rate around 90 % among hobbyists[BadFlash Guide].
Can I overclock the E5440 on this board?
Yes. Raise FSB to 400 MHz for 3.4 GHz. Most chips stay stable at ≤1.30 V, keeping load temps under 70 °C with a 120 mm tower cooler[User OC Database, 2023].
What RAM and GPU pair well with this setup?
Use 8 GB DDR2-800 in dual-channel and a mid-range GPU like GTX 1050 Ti. Faster DDR2 gains <3 % FPS, so spend on the graphics card instead[Elektroda, Karaczan, post #16567261]
Is upgrading LGA775 still worth it in 2025?
Only for budget or nostalgia builds. A 60 PLN E5440 upgrade can triple multithread score versus an old Pentium D, but any modern Ryzen 3 will still double that again[Geekbench Scores, 2024].
