What is the best processor for Socket 775? Or maybe replacing the whole MOBO?
szajsung22 8886 11
What is the best processor upgrade for Socket 775, or should I replace the motherboard and other core components instead?
A Q9650 is not worth buying for Socket 775; a modded Xeon for about 60–80 PLN is the better CPU upgrade option [#17014821] [#17014827] If you are replacing only the processor, choose the Xeon instead of spending more on a Q9650 [#17014827] If you can move to a new platform with a budget around 1.5k PLN, one suggested set was an i3-8100, ASRock Z370 PRO4, 8 GB DDR4, and be quiet! SYSTEM POWER 8 500W [#17014863] That build can use integrated graphics at first, and the old Radeon is considered worse than the integrated GPU [#17014841] The responder also said that budget is enough for this kind of set, and later you can add a separate graphics card if needed [#17014896] [#17014841]
  • #1 17014790
    szajsung22
    Hello. I warn you: there were topics on this topic in the forum, but they were not about my motherboard. So to the point. I have the ASUS P5G41T-M LX motherboard. Currently, the Intel Pentium E5700 @ 3.00GHz sits comfortably in the socket. According to my calculations, this processor is probably one of the best on Socket 775 (I do not know). But my question: what is the best processor for Socket 775? And if there is no sensible one, then can it replace the whole motherboard, processor, graphics card (mine is shit), and my power supply (also shit)? I look forward to your suggestions.
    Kasek21
    Help: 4981
    Rate: 3547
    Correct the calculations :)
    Full computer configuration?
    Application?
    Budget?
  • #3 17014819
    szajsung22
    Intel Pentium Dual-Core E5700 @ 3.00GHz
    ASUS P5G41T-M LX
    ATI Radeon HD3650 256MB RAM
    Power Man 300W power supply (szajs, blacklisted)
    Seagate 500GB
    Broadcom 802.11 Wi-Fi network card
    DVD-RW OPTIARC drive
    Kasek21 wrote:
    Application?
    "Office matters", Pinball games or browser snail Bob games, Internet browsing, Facebook, YouTube
    Kasek21 wrote:
    Budget?
    If we choose the option of modernizing only the processor on Socket 775, then I would like to spend no more than PLN 250. However, if we choose the MOBO + CPU + GPU + PSU upgrade option, then the budget is up to PLN 1,500.
    technikabasenowa
    Help: 138
    Rate: 445
    Q9650 but is it worth it :D
    Kasek21
    Help: 4981
    Rate: 3547
    No.
    Mount Xeon for 60-80 PLN.
    To read:
    https://www.elektroda.pl/rtvforum/topic2741899.html
    https://www.elektroda.pl/rtvforum/topic2946992.html
    If you can spend 2-2.2k PLN, you can think about something new - IT IS WORTH CHOOSING!
  • #6 17014834
    szajsung22
    And if we modernize CPU + MOBO + GPU + PSU ??? What set would you recommend ????
    Kasek21
    Help: 4981
    Rate: 3547
    Unless for now a set without separate graphics? ... and so the integrated system will be much more efficient than your Radeon :)
    You will buy a card in time.
  • #8 17014850
    szajsung22
    Yeah, I can use the integrated, I even thought about it ... :-)
    But what motherboard to buy, processor, RAM and with and s and l and c with ?
  • #9 17014863
    Kasek21
    Help: 4981
    Rate: 3547
    i3-8100, ASRock Z370 PRO4, 8GB DDR4, be quiet! SYSTEM POWER 8 500W
  • #10 17014885
    szajsung22
    I did list in the morele.net store - is such a set enough?
  • #11 17014896
    Kasek21
    Help: 4981
    Rate: 3547
    Yes, that's enough - there's nothing else to fit in these 1.5k zlotys.
    Now write if your disks / drives are on SATA?
  • #12 17014904
    szajsung22
    Kasek21 wrote:
    Are your drives / SATA drives SATA?
    Yes, and the disk and DVD drive is on SATA. The disk is on SATA II and the drive I do not know, I only know that the plug is SATA.
The discussion revolves around upgrading an ASUS P5G41T-M LX motherboard currently housing an Intel Pentium E5700 processor. The user seeks advice on the best processor for Socket 775, with suggestions including the Intel Core 2 Quad Q9650 and Xeon processors as potential upgrades. However, there is a consensus that a complete system upgrade, including a new motherboard, CPU, GPU, and power supply, may be more beneficial. Recommendations for a new setup include an Intel i3-8100 processor, ASRock Z370 PRO4 motherboard, 8GB DDR4 RAM, and a 500W power supply. The user confirms that their storage devices are SATA compatible, which is essential for the new components.
TL;DR: 60–80 PLN Xeon mod is the best value for LGA775; “Mount Xeon for 60–80 PLN.” If you can spend 2–2.2k PLN, go new platform. [Elektroda, Kasek21, post #17014827]
Why it matters: It helps LGA775 owners decide between a cheap CPU swap and a modern rebuild for office, YouTube, and light games.
What’s the best processor for Socket 775 right now?
On LGA775, the Core 2 Quad Q9650 is classic high end, but not worth it here. The standout value is an LGA771 Xeon mod for about 60–80 PLN. “Mount Xeon for 60–80 PLN.” If you can spend 2–2.2k PLN, a new platform is better. [Elektroda, Kasek21, post #17014827]
Is my Pentium E5700 among the best LGA775 CPUs?
No. A forum expert responded to that claim with, “Correct the calculations.” Consider the low‑cost Xeon mod or a platform upgrade instead. [Elektroda, Kasek21, post #17014792]
What is an LGA771‑to‑775 Xeon mod?
It’s a method, explained in the linked forum guides, to run select LGA771 Xeons in LGA775 motherboards. Typical CPU cost is 60–80 PLN. It’s the recommended budget path when staying on 775. [Elektroda, Kasek21, post #17014827]
Will an ASUS P5G41T‑M LX work with a Xeon mod?
The forum recommends the Xeon path and links guides for compatibility checks. Review those resources first and confirm your exact board and BIOS support. [Elektroda, Kasek21, post #17014827]
Should I replace the whole platform if I can spend around 2–2.2k PLN?
Yes. The advice was to choose a modern platform at that budget. “If you can spend 2–2.2k PLN… IT IS WORTH CHOOSING!” You will gain performance and upgrade headroom. [Elektroda, Kasek21, post #17014827]
Can I skip a dedicated GPU and use integrated graphics for now?
Yes. The integrated graphics on a modern CPU will be much faster than your Radeon HD3650. “...the integrated system will be much more efficient than your Radeon.” Add a discrete GPU later if needed. [Elektroda, Kasek21, post #17014841]
What parts were recommended for a fresh build?
Suggested kit: Intel Core i3‑8100, ASRock Z370 PRO4, 8 GB DDR4, and be quiet! System Power 8 500W. This provides a solid, modern baseline with integrated graphics. [Elektroda, Kasek21, post #17014863]
What budget should I set for a CPU‑only LGA775 upgrade?
The ceiling stated was 250 PLN for a CPU‑only 775 upgrade. Shop within that limit if you plan to keep the platform. [Elektroda, szajsung22, post #17014819]
What budget did the user allow for a full platform refresh?
Up to 1,500 PLN for motherboard, CPU, GPU, and PSU. That number frames the suggested parts list and staged GPU approach. [Elektroda, szajsung22, post #17014819]
Will my SATA hard drive and DVD‑RW work with the new build?
Yes. You confirmed both devices use SATA, which modern boards support. You can reuse them after the upgrade. [Elektroda, szajsung22, post #17014904]
How do I upgrade to a Xeon mod safely?
  1. Read the Xeon‑on‑775 guides linked in the thread.
  2. Source a compatible Xeon and the required components as described.
  3. Install per guide and test. Edge case: if it fails to POST, revert and recheck the guide steps. [Elektroda, Kasek21, post #17014827]
What tasks will a new i3‑8100 system handle well?
For office work, browsing, Facebook, YouTube, and simple games, the i3 build with integrated graphics is sufficient. Its integrated graphics outperform your Radeon HD3650. [Elektroda, Kasek21, post #17014841]
