Best Processor for Socket 1155: Upgrade from Intel Core i5-3570K CPU @ 3.40GHz
1Ender1 2427 15
Is it worth upgrading an Intel Core i5-3570K on LGA1155 for web browsing and Linux use?
No, for internet browsing and Linux use the i5-3570K is already enough, so replacing it on LGA1155 usually does not make sense [#20327670][#20327947][#20348640] If you want to experiment, the natural upgrade on this platform is an i7-3770K [#20327670] However, the GA-Z77M-D3H has weak power phases, so overclocking will be limited even though the unlocked multiplier makes it possible [#20327652] One reply also notes that for this old platform the performance gain is poor relative to the price [#20327815] The owner later agreed that there was little point in making the change [#20348640]
  • #1 20327600
    1Ender1
    Hi! Does it make sense to change the Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz? Socket 1155
    Taken from the topic: Which processor for socket 1155?
    by dt1 on 10 Dec 2022 07:59
  • #2 20327604
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Hi. There is or there isn't - depending:
    - what applications you want to buy it for and what you expect from it
    - what kind of motherboard you have
    - how much you want it to cost
  • #3 20327630
    1Ender1
    Board GA-Z77M-D3H
    Linux Peppermint
  • #4 20327634
    dt1
    Help: 7315
    Rate: 8292
    This provides the answer to one of the three questions. We are moving in the right direction.
  • No meaningful upgrade path beyond overclocking
    #5 20327643
    1Ender1
    12 GB Ram
    So far I haven't thought about what budget.
    Application internet review. And that's all there is to it.
    Or overclocking the CPU?
    Current data from the terminal
    Getting SMBIOS data from sysfs.
    SMBIOS 2.7 present.
    Handle 0x0043, DMI type 4, 42 bytes
    Processor Information
    Socket Designation: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
    Type: Central Processor
    Family: Core i7
    Manufacturer: Intel
    ID: A9 06 03 00 FF FB EB BF
    Signature: Type 0, Family 6, Model 58, Stepping 9
    Flags:
    FPU (Floating-point unit on-chip)
    VME (Virtual mode extension)
    DE (Debugging extension)
    PSE (Page size extension)
    TSC (Time stamp counter)
    MSR (Model specific registers)
    PAE (Physical address extension)
    MCE (Machine check exception)
    CX8 (CMPXCHG8 instruction supported)
    APIC (On-chip APIC hardware supported)
    SEP (Fast system call)
    MTRR (Memory type range registers)
    PGE (Page global enable)
    MCA (Machine check architecture)
    CMOV (Conditional move instruction supported)
    PAT (Page attribute table)
    PSE-36 (36-bit page size extension)
    CLFSH (CLFLUSH instruction supported)
    DS (Debug store)
    ACPI (ACPI supported)
    MMX (MMX technology supported)
    FXSR (FXSAVE and FXSTOR instructions supported)
    SSE (Streaming SIMD extensions)
    SSE2 (Streaming SIMD extensions 2)
    SS (Self-snoop)
    HTT (Multi-threading)
    TM (Thermal monitor supported)
    PBE (Pending break enabled)
    Version: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
    Voltage: 1.1 V
    External Clock: 100 MHz
    Max Speed: 7000 MHz
    Current Speed: 3600 MHz
    Status: Populated, Enabled
    Upgrade: Other
    L1 Cache Handle: 0x0004
    L2 Cache Handle: 0x0005
    L3 Cache Handle: 0x0006
    Serial Number: Not Specified
    Asset Tag: Fill By OEM
    Part Number: Fill By OEM
    Core Count: 4
    Core Enabled: 1
    Characteristics:
    64-bit capable
  • Limited overclocking on weak power phases
    #6 20327652
    dt1
    Help: 7315
    Rate: 8292
    The bare and poor power phases on this board allow us to assume that overclocking on this board will be quite limited. But possible at all, as there will be an unlocked multiplier on this configuration. So if you want to play around with OC and budget isn't important, why not. I'd spend a maximum of PLN100 on a ten year old processor of this class and you can buy it for that much.
    Don't forget a reasonable grade thermal heatpaste and better than BOX cooling if you want to approach the OC topic.
  • #7 20327661
    1Ender1
    I have an oversized heatsink, the power supply is also Bequiet
    What kind of CPU do you suggest?
  • #8 20327670
    dt1
    Help: 7315
    Rate: 8292
    I misread the first post. You don't want to change to, just from an I5-3570K. So you can on an I7-3770K, but for internet browsing it doesn't make much sense.
  • #9 20327721
    qrek1
    Help: 487
    Rate: 615
    1Ender1 wrote:
    Hello: Does it make sense to change the Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
    Doesn't make sense
  • Sell the i5-3570K platform before retro prices drop
    #10 20327815
    Tomek_Krecik
    Help: 120
    Rate: 232
    1Ender1 wrote:
    How about switching to an Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz ? Socket 1155
    With the current advancements and prices under your old platform, it doesn't make any sense.
    From whichever side you look at it. Performance-wise or price-wise.
    Sell as soon as possible while this hardware has not yet entered the retro zone.
    I did this two years ago and still managed to get something reasonable out of it.
    You have the last call to sell it.
    After that, it's on to the three Mirindas from the Frog Shop....
  • #11 20327947
    rupert201
    Help: 60
    Rate: 162
    Hello, your advice is "priceless". The author uses the computer to browse the internet. And he asks, is it worth changing the processor? It's not worth it, because what he has is sufficient for that. If he was looking for a processor(or computer) for gaming, then a replacement could be advised.
  • Questioning whether the CPU is actually underperforming
    #12 20328049
    n.vision
    Help: 108
    Rate: 260
    rupert201 wrote:
    The author uses the computer to browse the internet. And he asks, is it worth changing the processor? It's not worth it, because the one he has is sufficient for that.
    Well that's interesting, why then is he even asking if the one he has works perfectly well. "I have a processor that performs well and there are no problems with it and I'm happy with the performance, but all in all I would do something because I have 3 hundred dollars too much I will take the time of the people on the electrode to understand what I'm even talking about." - Either that or something is wrong with the performance after all, but that's something we'll have to ask the topic manager I guess. I'm not ruling out either option.
  • #13 20328251
    gr0szek129
    1Ender1 wrote:
    Hi, is there any point in changing the Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz ? Socket 1155
    Since you already have an i5 and the computer is supposed to be for browsing the internet then it doesn't make much sense to change it, alternatively you might be interested in the topic of xeon e3 as you can often find good bargains.
  • #15 20328425
    dt1
    Help: 7315
    Rate: 8292
    ADB-6 wrote:
    This page contains all intel processors on the LGA1155 socket.
    This adds little to the topic. If you have any thoughts on whether the Author's processor is worth replacing with another - that's the topic and worth writing about.
  • #16 20348640
    1Ender1
    All in all, you're right.
    After much thought, I don't see much sense in such a change. Internet works, Linux on board. That's what I thought as well, but wanted to make sure and get other people's opinions. Thank you all for your time.
    Regards
The discussion centers around whether it is worthwhile to upgrade from the Intel Core i5-3570K CPU, which operates at 3.40GHz and uses the Socket 1155 interface. The consensus among participants suggests that upgrading may not be necessary, as the current setup is sufficient for general tasks such as internet browsing and running Linux. The author expresses appreciation for the feedback received, indicating that the existing performance meets their needs.
