Brother DCP-130C: Can't Clean 46 Error & Maintenance Mode Procedure Explained
CMS 10158 2
  • #1 16569876
    CMS
    Help: 258
    Rate: 2601
    I have a problem with the Brother DCP-130C.
    I get error "Can't Clean 46"
    I tried to follow the procedure:
    - Disconnect the power cord plug from the device
    - Press the MENU button
    - Connect the plug with the MENU button pressed
    - The following text will appear on the LCD display: >> Maintenance > Maintenance
    Maintenance mode reset for purge counter
    #2 16570056
    fifek62
    Help: 66
    Rate: 288
    Hello!
    Pampers full. Need to delete.
    1. Disconnect the power cord
    2. While holding the menu button, connect the power cord
    3. We will see the MAINTENANCE mode
    4. Use the up-down arrows to select number 8 and confirm with OK
    5. Then choose the number 0 and OK
    6. Now press the Mono button 25 times until the PURGE: xxxxx message appears
    7. Select with arrows 2, confirm with OK, 7 with OK, 8 with OK, 3 with OK.
    8. We should get PURGE: 00000
    9. Disconnect the printer from the network and reconnect
    10. At this point, the cleaning counter is reset and the printer is ready for printing.
  • #3 16571430
    CMS
    Help: 258
    Rate: 2601
    Zatrybiło.
    Thank you very much.
    Best regards.
    CMS
