Brother Printers: Checking Print Counts for MFC-5860CN, MFC-J415W, DCP-J315W, and HL-2030 Models
Norbas78 14199 11
How can I check the print counter or mileage on Brother printers such as the MFC-5860CN, MFC-J415W, DCP-J315W, and HL-2030?
Yes — on Brother machines you can usually read the total page count in maintenance mode 80, and on inkjet models it works analogously. To enter it, unplug the power cord, hold Menu while plugging it back in, then choose 8 OK 0 OK; use the arrows to move through items and Mono Start to change them [#17127289] In maintenance 80, the key counter is TTL_PG, which shows the total number of pages printed; related fields include TTLCOPY for copies and TTLPCPT for pages printed via PC [#17127030] For the HL-2030 specifically, three quick presses of the Go key show a sheet counter plus drum and toner replacement counters [#17123831]
  • #1 17123659
    Norbas78
    Rate: 79
    I have to check the "mileage" in several second-hand printers.
    Printers are:
    MFC-5860CN
    MFC-J415W
    DCP-J315W
    HL-2030
    Is it feasible?
    Or maybe there is one way that works on this company's printers?
    Thanks in advance.
    best regards
  • #2 17123831
    rb401
    Help: 750
    Rate: 984
    Norbas78 wrote:
    HL-2030
    Three quick (within 2 seconds) presses of the Go key. There is a sheet counter and drum and toner replacement counters.
    dr.master
    Help: 518
    Rate: 927
    W tym momencie nie pamiętam która pozycja, ale na pewno wchodząc w maintenance 80 jesteś w stanie odczytać numer seryjny oraz licznik stron.
    We wszystkich atramentówkach będzie analogicznie.
    Już sobie przypomniałem :
    TTL_PG:00000000 tu jest całkowita liczba wydrukowanych stron
    TTLCOPY:00000000 tu jest całkowita liczba zrobionych kopii
    TTLPCPT:00000000 tu jest całkowita liczba stron wydrukowanych za pośrednictwem komputera
    A tu rozpiska maintenance 80 :
    MACERR_##:0000 Machine error log (last ten errors) *1
    USB:000G8J000166 Serial number *2
    MAC:008077112233 MAC address
    PCB:911309123456 Main PCB serial number
    KTN_ERM:87% Estimated remaining toner amount based on the average coverage
    KTN_RRM:67% Estimated remaining toner amount based on the rotations of
    develop roller
    DRUM_PG:00000000 Printed pages for drum unit
    PFMP_PG:00000000 Pages fed from PF kit MP
    PFK1_PG:00000000 Pages fed from PF kit 1
    PFK2_PG:00000000 Pages fed from PF kit 2
    PFK3_PG:00000000 Pages fed from PF kit 3
    PFK4_PG:00000000 Pages fed from PF kit 4
    PFK5_PG:00000000 Pages fed from PF kit 5
    FUSR_PG:00000000 Printed pages for fuser unit
    LASR_PG:00000000 Printed pages for laser unit
    TTL_PG:00000000 Total number of pages printed
    DX_PG:00000000 Paper input for duplex tray
    TTLCOPY:00000000 Total pages copied
    DX_COPY:00000000 Total pages copied on both sides
    TTLPCPT:00000000 Total pages printed via PC
    DX_PCPT:00000000 Total two-sided pages printed via PC
    TTLFAX:00000000 Total List / Fax pages printed *3
    DX_FAX:00000000 Total List / Fax pages printed on both sides *3
    TTL_OTH:00000000 Total pages printed by other methods
    DX_OTH:00000000 Total two-sided pages printed by other methods
    5-55 Confidential
    KCVRGUSI:4.32% Average coverage by the current toner cartridge
    KCVRGACC:3.47% Accumulated average coverage
    DRUM:00000000 Rotations of the drum *4
    KTN_RND: 00000000 Rotations of the develop roller *4
    MP_PG:00000000 Paper input for MP tray
    TR1_PG:00000000 Paper input for paper tray
    TR2_PG:00000000 Paper input for paper tray 2
    TR3_PG:00000000 Paper input for paper tray 3
    TR4_PG:00000000 Paper input for paper tray 4
    TR5_PG:00000000 Paper input for paper tray 5
    STDEJ:00000000 Paper output for machine output tray
    DX_PG:00000000 Paper passed through duplex tray
    A4+LTR:00000000 Total paper input for A4 and Letter
    LG+FOL:00000000 Total paper input for Legal and Folio
    B5+EXE:00000000 Total paper input for B5 and Execute
    ENVLOP:00000000 Paper input for Envelope
    A5 :00000000 Paper input for A5 (including A5 Landscape)
    OTHER :00000000 Paper input for other sizes
    PLTNRE:00000000 Total printed pages of plain, thin, and recycled paper
    TKTRBD:00000000 Total printed pages of thick, thicker, and bond paper
    ENVTYP:00000000 Total printed pages of envelope, thick envelope, and thin
    envelope
    LABEL:00000000 Printed labels
    HAGAKI:00000000 Printed postcards
    COLOR:00000000 Full-color printed pages
    LTHD:00000000 Printed pages per letter head
    GLOSSY:00000000 Total pages printed on glossy paper
    TTL_JAM:00000000 Total paper jams that have occurred
    MP_JAM:00000 Paper jams that have occurred in the MP tray
    TR1_JAM:00000000 Paper jams that have occurred in paper tray 1
    TR2_JAM:00000 Paper jams that have occurred in paper tray 2
    TR3_JAM:00000 Paper jams that have occurred in paper tray 3
    TR4_JAM:00000 Paper jams that have occurred in paper tray 4
    TR5_JAM:00000 Paper jams that have occurred in paper tray 5
    IN_JAM:00000000 Paper jams that have occurred in the machine
    LCD Description
    5-56 Confidential
    RE_JAM:00000000 Paper jams that have occurred at the ejecting section or back
    cover
    DX_JAM:00000000 Paper jams that have occurred in the duplex tray
    POWER:00000375 Total power distribution time (unit: hour)
    PWRCNT:00000001 The number of times that the power is turned ON
    KTN_CH:0000 The number of times that the toner cartridge has been replaced *4
    DRUM_CH:0000 The number of times that the drum unit has been replaced *4
    FUSR_CH:0000 The number of times that the fuser unit has been replaced *4
    LASR_CH:0000 The number of times that the laser unit has been replaced *4
    PFMP_CH:000 The number of times that the PF kit MP has been replaced
    PFK1_CH:000 The number of times that the PF kit 1 has been replaced
    PFK2_CH:000 The number of times that the PF kit 2 has been replaced
    PFK3_CH:000 The number of times that the PF kit 3 has been replaced
    PFK4_CH:000 The number of times that the PF kit 4 has been replaced
    PFK5_CH:000 The number of times that the PF kit 5 has been replaced
    KTN_PG1:00000000 Pages printed with the current toner cartridge
    KTN_PG2:00000000 Pages printed with the previous toner cartridge
    WTNR_PG:00000000 The number of pages printed from the waste toner box
    SCN_PG:00000000 The number of scanned pages (except Fax and Copy)
    ADSX_PG:00000000 ADF single-side scanned pages (duplex scanning models only)
    ADDX_PG:00000000 ADF double-side scanned pages (duplex scanning models only)
    ADTL_PG:00000000 Total pages of ADSX_PG and ADDX_PG
    FB_PG:000000 Total FB scanned pages
    ADSX_JAM:000000 Document jams that have occurred on ADF single-side scanning
    ADDX_JAM:000000 Document jams that have occurred on ADF duplex scanning
    FXTX_PG The number of faxed pages
    COMERR#:00000000 Communication error log (past three errors) *5
    (models with fax only)
    KDEV_BIAS:400V Black developing bias voltage value
    ENGERR##:000000 Engine error log (last ten errors) *6
    HODN_ER:0000 The number of discharge errors occurred
    FUSR_ER:0000 The number of fuser unit errors occurred
    MTLK_ER:0000 The number of polygon motor lock errors occurred in the laser scanner
    DEVSTATUS__##:00 Log for design analysis *7
  • #4 17127269
    Norbas78
    Rate: 79
    Thanks a lot mate.
    I understand that I use the arrows in this menu?
    And how to get into them and what not to do so as not to make a bigos for yourself?
  • #5 17127289
    dr.master
    Help: 518
    Rate: 927
    Yes, you move with the arrows.
    To enter the maintenance menu, you unplug the power cord, press the menu key and, with the menu pressed, plug the cord into the socket.
    Use the arrows to select 8 OK 0 OK.
    To change subsequent items in maintenance 80 you press mono start.
  • #6 17127299
    Norbas78
    Rate: 79
    Cool. Maybe I can check on two printers tonight.
    Is there any crack / translation for maintenance menu somewhere on the web?
    I would like to add something like this to my "toolbox" because the translator, unfortunately, can write miracles.
  • #7 17127322
    dr.master
    Help: 518
    Rate: 927
    I wouldn't count on that.
    You don't really need most of it.
    Search the forum for the service manual and read on.
    A google translator should guide you, ask in case of problems :D
  • #8 17519884
    jacekkr54
    Hello, I have a question, how to reset the counter of printed pages in the BROTHER DCP-J140W printer?
  • #9 17519910
    dr.master
    Help: 518
    Rate: 927
    I hope he won't trade as a newcomer ...
    You enter the maintenance menu, then 80, and there you have a page count.
    At that item, you select 2783 to delete it.
  • #10 17519966
    jacekkr54
    No, it will stay with me until the end, what English name will be on the display, will all values, all, color copies, mono copies, etc. be reset?
  • #11 17519992
    dr.master
    Help: 518
    Rate: 927
    Look in my answers, there is a list somewhere which name is responsible for.
    So far, 0 attempts to solve the problem on your own.
  • #12 17520029
    jacekkr54
    whether it could be "Total pages copied" or "Total pages printed by other methods", or some other name, I wouldn't want to damage something. Is it about the post on 3/25/18?
To check the print counts on Brother printers MFC-5860CN, MFC-J415W, DCP-J315W, and HL-2030, users can access the maintenance menu. For most models, this involves unplugging the power cord, pressing the menu key, and then plugging the cord back in while holding the menu key. Navigate to maintenance mode by selecting 8 and then OK. The total printed pages can be found under TTL_PG, while other counters like TTLCOPY and TTLPCPT provide additional information on copies and computer-printed pages. Users are advised to refer to service manuals for detailed instructions and to use caution to avoid unintentional changes.
TL;DR: For Brother MFC/DCP models, open Maintenance 80 by selecting 8 OK 0 OK; "You move with the arrows." Then press Mono Start to step counters. [Elektroda, dr.master, post #17127289]
Why it matters: This helps buyers and techs quickly verify real page counts and service history on used Brother printers.
How do I check the page count on a Brother HL‑2030?
Press the Go key three times within two seconds. The printer prints a status sheet. It includes the sheet counter and drum and toner replacement counters. "Three quick (within 2 seconds) presses of the Go key." [Elektroda, rb401, post #17123831]
How do I enter Maintenance 80 on MFC‑J415W, DCP‑J315W, or MFC‑5860CN?
  1. Unplug power. Hold Menu, then plug the cord back in.
  2. Use arrows to select 8 OK 0 OK to open Maintenance 80.
  3. Press Mono Start to step through subsequent items. "You move with the arrows." [Elektroda, dr.master, post #17127289]
Which menu item shows total printed pages on these Brother inkjets?
Open Maintenance 80 and look for TTL_PG. It is the total number of pages printed. You can also review TTLCOPY for copies and TTLPCPT for pages printed via PC. "TTL_PG: Total number of pages printed." [Elektroda, dr.master, post #17127030]
Can I reset the total page counter on a DCP‑J140W?
Yes. Enter Maintenance 80, highlight the page‑count item (e.g., TTL_PG), then input 2783 to delete it. "At that item, you select 2783 to delete it." Only use resets if you understand the implications. [Elektroda, dr.master, post #17519910]
If I reset TTL_PG, will it also reset copies or PC prints?
No. Resets apply to the selected item only. "At that item, you select 2783 to delete it." To clear TTLCOPY or TTLPCPT, repeat the reset at those specific items within Maintenance 80. [Elektroda, dr.master, post #17519910]
What do TTLCOPY, TTLPCPT, and TTL_OTH mean?
TTLCOPY is total pages copied. TTLPCPT is total pages printed via PC. TTL_OTH is total pages printed by other methods. These labels appear under Maintenance 80 and segment usage by source. "TTLPCPT: Total pages printed via PC." [Elektroda, dr.master, post #17127030]
Where can I see drum, fuser, and toner usage counters?
Maintenance 80 lists DRUM_PG (printed pages for drum), FUSR_PG (fuser), and LASR_PG (laser). It also tracks KTN_CH (times toner replaced), DRUM_CH, FUSR_CH, and KTN_PG1/KTN_PG2 for pages on current/previous toner. These help assess consumable wear. [Elektroda, dr.master, post #17127030]
How do I move through Maintenance 80 without changing values?
Use the arrow keys to navigate items. Press Mono Start to show subsequent entries within Maintenance 80. Avoid entering numeric codes unless you intend to reset a specific field. "You move with the arrows." [Elektroda, dr.master, post #17127289]
Where do I find my Brother device's serial number and MAC address in Maintenance 80?
Look for USB: which shows the serial number. MAC: shows the MAC address. PCB: lists the main PCB serial number. These fields appear alongside counters in Maintenance 80 for quick identification. [Elektroda, dr.master, post #17127030]
Can I see jam counts and power‑on hours in Maintenance 80?
Yes. Review TTL_JAM for total jams and MP_JAM/TRx_JAM for tray‑specific jams. POWER shows total power‑on hours, and PWRCNT shows how many times the device was turned on. The machine error log keeps the last ten errors. [Elektroda, dr.master, post #17127030]
Why don’t duplex or ADF counters show on my model?
Some fields appear only on supported hardware. ADSX_PG and ADDX_PG exist on duplex scanning models only. ADTL_PG totals those values. If your device lacks duplex ADF, those entries will not appear. [Elektroda, dr.master, post #17127030]
Is there a translated cheat sheet for Maintenance 80 names?
A complete public translation is unlikely. The recommended path is to consult the service manual. "A google translator should guide you, ask in case of problems." Use the forum manual references for specifics. [Elektroda, dr.master, post #17127322]
Does the HL‑2030 status page include drum and toner counters too?
Yes. The printout includes the sheet counter and counters for drum and toner replacements. This quick check helps assess consumable history without entering service mode. "There is a sheet counter and drum and toner replacement counters." [Elektroda, rb401, post #17123831]
Are the steps the same across Brother inkjets like MFC‑J415W and DCP‑J315W?
Yes. The technician notes, "We wszystkich atramentwkach będzie analogicznie." In practice, access Maintenance 80 and read TTL_PG/TTLCOPY/TTLPCPT similarly across these inkjet models. [Elektroda, dr.master, post #17127030]
